    Help setting up SFTP with a pi zero w with a static IP address
    helpsftpstaticip address
    4 Posts 3 Posters 3.5k Views
      pleasehelpme
      Hi,
      I followed this tutorial, the pi is assigned the IP I give it but when attempting to access it using WinSCP I always recieve the same message:
      Network error connection to (myip) refused.
      The server rejected SFTP connection, but listens for FTP connections.
      I tried using FTP but I was just met with "The target machine actively refused it".
      Please help :)
        BuZz administrators @pleasehelpme
        @pleasehelpme Did you enable SSH ? https://retropie.org.uk/docs/SSH/
          pleasehelpme
          Wow... that was easy.
          • DarkWolfD
            DarkWolf
            Common mistake :)
            System: Raspberry 3 Model B, RetroPie 4.2.1
            Storage: 16gb Micro SD, 64gb USB Drive
            Theme: Updated NBBA
            Documentation solves many problems: https://retropie.org.uk/docs/
