    Pi zero usb snes controller not detected
    pi zerousb controller
    1 Posts 1 Posters 587 Views
      codinglock
      Hello everyone, so i have a pi zero, I soldered a working usb hub to it and it works. I can plug my blue tooth adapter and wired xbox 360 controller everything is kosher with that. However whenever i try to use my wired snes controller, i get not gamepads detected. I try to hook my keyboard up to it to and nothing works. I have tried this as well with a otg cable to the mini port on board and nothing will detect it. I'm running the 4.2 retropie. been trying to run the lsusb command but again it wont detect keyboard either from otg cable or usb hub any thoughts on this , thanks for the help.
