Several Problems on Raspberrypi3
@epd without any logs of sorts it's hard to troubleshoot.
Can you even login via SSH when it freezes?
At this stage, with the power issues and repeated power disconnects, I would not find it strange if your SD card had become corrupted somewhere, so in that sense a format and fresh install will probably be the way to go. Especially, as Buzz states, if you have a third party image.
When you boot, do you see any logs that suggest any faulty sectors?
@epd This is not the first time I have read about someone experiencing lockups on hotkey-exit with a third-party image. I couldn't find the thread just now, but someone within the past week or two had the same issue and then we realized they had been using a pre-built image without much detail as to the source. This is not the first time, and I expect far from the last that we will see this symptom.
I am using the ps3 controller wired, i have not used bluetooth at all, yes there seems to be two red errors in the startup..
Yes i think a fresh install is a good option, ill follow the info in the docs. One thing, is emulation station a part of retropie or does that need to be installed too?
I looked at the documentation. Im going to reinstall. So i format the sd card, put the img file in, then is that Retropie installed?
@epd For the most part, yes. You need to add your ROMs, and set up your controllers, but other than that, should be good to go!
