    [Solved] Only two little Problems - view changed!
    retropieretropiemenuviewterminal
    2 Posts 1 Posters 918 Views
      BobbyDigital
      Hello, I have two little problems.
      First the view in "retropie/configuration" is changed and the images are missing. Secondly in the terminal is an error-message.
      Retropie-Configuration:
      Terminal:
      The following error message is displayed
      The xml-File exist but the file is empty.
      Thanks for helping... :)
        BobbyDigital
        Hello, I found a solution. :)
        I uninstall and reinstall the retropiemenu.
