    Problems detecting gamepads and keyboards for the firs time
    configurationgamepad configinitial setup
    1 Posts 1 Posters 572 Views
    • L
      lumalav
      Pi Model or other hardware: B
      Power Supply used: CanaKit 2.5A
      RetroPie Version Used: 4.2
      Built From: Pre made SD Image on RetroPie website retropie-4.2-rpi2_rpi3.img
      USB Devices connected: Microsoft Wired Keyboard 400
      Controller used: Logitech F310
      Error messages received: None
      Log found in /dev/shm/runcommand.log (if relevant): haven't tried to ssh yet
      Guide used: official
      File: n/a
      Emulator: n/a
      Hi,
      So basically the same as the title. I'm completely new to the raspberry pi and retropie. And even though installing the image was fairly simple, after I start the Pi, the system does not recognize anything. Not even the keyboard. I am only using wired stuff. No wireless peripherals at all. One of the controllers that I have is the Logitech F310. I saw a couple of links mentioning that the issues with that controller were fixed a long time ago. However, I think my problem is about power. No led on any of the controllers. Do I need more power to use the F310? Do I have to buy a USB hub? What about the keyboard. It is just an old Microsoft wired keyboard 400. What is happening? What can I do to troubleshoot this if I can even pass from the first screen?
      Thank you
