Help with Mame4all and attract-mode
Hi, I'm trying to set up attract mode with retropie. I can't seem to get Mame4all to work.
When I try and launch mame a black screen with code flashes and disappears.
Can someone tell me what I should put for these:
Executable
Command arguments
Snap
WheelI can see my full rom list but I can't play any of them. I am using a Raspberrypi 3.
Thanks in advance!
@Scout43 said in Help with Mame4all and attract-mode:
Executable
Command arguments
Snap
Thanks in advance!
What image are you using or did you compile your own. Need to know if your using the X version or the non X, it takes different exe and arg to run.
Assuming you are running a non-X version of AM, here is the emulator file
Sweet! I'll try it and let you know.
@Floob
I'm very new so by non x do you mean I start it without Xinit? The way I start it is by quitting emulation station and typing attract. -
Yes!!! Thank you very much I got it to work!
Have you built your own Attract Mode setup? If so, if it runs by just typing "attract" then yes, that file I linked to above should work.
X allows programs to use a certain GUI method:
https://en.wikipedia.org/wiki/X_Window_SystemThis is what Attract Mode used to require, but now it can be run with or without X. xinit starts X.
