[SOLVED] lr-ppsspp emulator does not work, please help !!
@darthlink not sure what a
plateform
is and tags have to match command does not match with ROMs.Might just be easiest for you to delete your es_systems config and do a full install
@herb_fargus said in lr-ppsspp emulator does not work, please help !!:
plateform
i do not need to delete my es_systems.cfg because it is working right now with the psp part removed.
if that line does not match <command>bash %ROMS%</ROMS> then what should it be?
yeesss a new advance, now psp is finally showing in emulationstation.
i added back the psp part but i changed this <command>bash %ROMS%</ROMS> to <command>bash %ROMS%</command>
the only problem now is that the rom i have in it witch is little big planet does show but it does not start. i get the error:
bash %ROM% no such file or directory
so anyone can help me to be able to start a rom in psp please ?
now i changed: <command>bash %ROMS%</ROMS> to <command>bash %ROM%</ROMS>
and it still does not start but i get a new error when i start little big planet.
the error point to the .iso of the game but it says: cannot execute binary file
so i added .bin in the extensions but i still get the same error ???
how can i start the game ?
@darthlink
I posted the code for the system above<system> <name>psp</name> <fullname>PlayStation Portable</fullname> <path>/home/pi/RetroPie/roms/psp</path> <extension>.iso .ISO. cso .CSO .pbp . PBP</extension> <command>/opt/retropie/supplementary/runcommand/runcommand.sh 0 _SYS_ psp %ROM%</command> <platform>psp</platform> <theme>psp</theme> </system>
Some side notes:
XML tags starting with a word/tag name between<...>
and end with the same between</...>
so you can't just write another word/tag name at the end, they have to match
bash %ROMS%
And what should this execute? your iso file is no bash script
@DarkWolf said in lr-ppsspp emulator does not work, please help !!:
@darthlink
Some side notes:
bash %ROMS%
Thank you very much, its finnally all working. The worst is that i had put that command line earlier but i think i had make a mistake in it and it mau have been why it was not working.
So now little big planet does start but not grand thef auto vice city, i ear the music but i get a black screen so i think it is the rom because LBP works fine.
Thank you so much for all your help, you are really great ;)
@darthlink
Haha, glad it finally worked!so i think it is the rom because LBP works fine
No, doesn't have to! But I don't know if the emulator supports it... You might have seen this on other systems to, some games work, some don't.
If that makes sense. -
Its ok, i am not a such a big fan of Grand thef auto anyway loll
May i stretch your help still on my other post about the PS4 controller please ?
I still cant play quake2 :( witch is a great game. I also saw quake 3 in ports and i had installed it but i could not see it anywhere so i uninstalled it. I dont know if it was only the engine and i was suppose to get the game and install it after that but in any case, i still would not have been able to play it if i cant get bot analog stick to work.
