    Need SFTP Help
    sftp error
    2 Posts 1 Posters 758 Views
      mhelfrich
      Hi,
      I attempted to follow the guide on the github site to transfer over SFTP.
      I downloaded WinSCP and made sure that both the RetroPie and the transfering computer were on the same network, but I'm still having issues.
      I am using the ip address as the hostname, while leaving the port as 22.
      If anyone could help that would be much appreciated.
      Thanks,
      Mark
        mhelfrich
        Hi All,
        So I figured it out. I realized I needed to enable SSH on the RetroPie as looking at further documentation that it is disabled by default. Once I did that I had no problem.
        Thanks,
        Mark
