    Pi is on and running, but total black screen
    pi3displayblack screen
    19 Posts 5 Posters 16.0k Views
      SpudsMcToole Banned
      Raspberry Pi model 3, Retropie 4.1.
      I was watching a movie, and when it ended the (PS3) joypad had switched off and I couldn't get it, or the second pad, to connect with the Pi (all four red lights just flashed endlessly), so I had no option but to pull the plug on the Pi to reset it.
      When I plugged it back in the pad connected fine, and all the lights on the Pi came on, but there was absolutely no signal to the screen.
      I checked the HDMI port on the TV, no problems there, other devices display fine. I tried a different HDMI lead with the Pi, made no difference. Haven't had any problems whatsoever with the display before.
      I can still hook up to the Pi through WinSCP - all the data is there, I can read and write to it in both directions. It thinks it's working fine. But I cannot for the life of me make it send a signal to the TV. Is there any sort of special reset I can do that might sort things out?
      • TMNTturtlguyT
        TMNTturtlguy @SpudsMcToole
        @SpudsMcToole first, have you tried a different tv or monitor?
        If you can't get signal to another screen, look at Setting in /boot/config.txt
        Try to change the following if it isn't already set to this.
        hdmi_drive=2
          pjft
          What does
          tvservice -s
          Report when you run it via SSH? Does that match a mode your TV supports?
            SpudsMcToole Banned @pjft
            @pjft My TV supports it fine, it's been running it for months.
              pjft @SpudsMcToole
              @SpudsMcToole that was not the question :)
              The output of that command will tell you what mode the Pi is sending the signal as. What does it report?
                @pjft It says:
                state 0x40002 [NTSC 4:3], 720x480 @ 60.00Hz, interlaced
                  SpudsMcToole Banned @TMNTturtlguy
                  @TMNTturtlguy It won't let me edit or delete config.txt.
                    pjft @SpudsMcToole
                    @SpudsMcToole thanks.
                    For you to edit config.txt you'll need to use
                    sudo nano /boot/config.txt
                    Does that mode sound right, though? Are you using a 4:3 TV, with that resolution?
                    Have you googled that state? I'm on my phone but that's what I'd do - that might give you a hint of what it's trying to output, and why your TV doesn't accept it.
                    You may need to force a specific resolution/display mode in config.txt.
                    • CodeDrawerC
                      CodeDrawer
                      I have that problem too. What I do to fix it, is let the TV boot up until it reaches the no signal screen (without the pi on) then I plug the pi in and it works! :) Hope this helped.
                      N64 emulation is the next step :)
                        pjft @CodeDrawer
                        If what others are suggesting doesn't work, I seem to have found a few mentions of that state on Google, which is weird.
                        https://raspberrypi.stackexchange.com/questions/43372/signal-from-pi-not-recognized-by-dp-monitor
                        http://openelec.tv/forum/124-raspberry-pi/71553-rpi-openelec-4-0-3-and-4-0-4-hdmi-config
                        Unfortunately, there doesn't seem to be a clear resolution to it - no pun intended. Let us know what you find.
                        • CodeDrawerC
                          CodeDrawer
                          What screen do you use? I use a 22 inch RCA TV... I think..
                            @pjft That gives me:
                            /boot$ sudo nano /boot/config.txt
                            Error opening terminal: unknown.
                            pjftP AlexMurphyA 2 Replies Last reply Reply Quote 0
                              pjft @SpudsMcToole
                              @SpudsMcToole huh. That's weird. You can also plug the SD card in your computer and edit the file, then. It's probably best.
                              • AlexMurphyA
                                AlexMurphy Banned @SpudsMcToole
                                @SpudsMcToole If you are already in /bootdirectory (which it appears you are from the command prompt) do not put in in again. Just type sudo nano config.txt
                                  SpudsMcToole Banned @AlexMurphy
                                  @AlexMurphy Same result, with or without the slash.
                                  /boot$ sudo nano config.txt
                                  /boot$ sudo nano /config.txt
                                    @pjft said in Pi is on and running, but total black screen:
                                    Tried the new firmware, no difference.
                                      SpudsMcToole Banned
                                      I've now managed to hook the Pi up to a different TV. Worked absolutely fine, so it's not the box itself that's buggered.
                                        SpudsMcToole Banned
                                        Huh. After connecting the Pi to the second TV, I put it back on the original one, having changed absolutely nothing. Worked perfectly. So if you find yourself having this problem, maybe give that a shot.
                                          pjft @SpudsMcToole
                                          @SpudsMcToole Thanks for sharing and closing this one off!
