    (WIP) Starting my first case mod. PS2 slim. Help and feedback greatly appreciated!
    projectdiyps2build
    47 Posts 8 Posters 14.9k Views
      Sturo
      @edmaul69 Wow I never knew the heat sink orientation was an issue, crazy! I've used the Pi pretty extensively, both the Wifi and bluetooth and haven't run into any huge problems with interference, so I may leave it as is for now.
      As for the ram, there is a gap underneath the board to allow it to breath a little. If it becomes an issue, I can find a place for the PS2 fan, and/or drill holes underneath the Pi's location for more breathing. Thanks for the suggestions!
        edmaul69 @Sturo
        @Sturo yeah not everyone has issues with their heatsink acting as an antenna, but some people do. I would definitely put some holes under the pi. As your ram starts to heat up it will also start heating everything above it if the heat cant escape fast enough.
          godhunter74 @Sturo
          @Sturo this is what i think :
          Concept1 is look like very to the original that is BIT funny
          Concept2 is beautiful this is my best choice
          Concept3 is weird i don't like it.
            Sturo
            Painting is going slow! I managed to make a splashscreen video. It's not perfect, I had to learn how to use a new software and I trudged through it, but I like it. It has that awesome sound!
              Sturo
              Hey everyone! For now, I am tentatively done. I've hit a good stopping point, I just need to figure out some small stuff on the software side. I will hopefully be back in the future after I fine tune the project and get it to exactly how I want it. (And maybe start a new project!) Thanks for everyone's help! If you have any solutions to the issues I mention in the video please feel free to give me a shout!
              • W
                Wulf @Sturo
                @Sturo
                I'd try to get a higher amperage power supply to your pie, see if that fixes any of your controller problems (not really sure if it's the cause, but you'll want to get a higher power power supply anyways).
                oh, and congratz on your progress so far!
                  Sturo
                  @Wulf I hooked it up to the original power supply and the controller was still acting up. I am going to hook up my old PS2 fat and try a game out on that to see if the controllers are bugged out. If not, it's the adapter and I am in a bit of a pickle.
                  UPDATE: So I hooked up the ol' fatboy and tested both of my controllers. They both work flawlessly. I dismantled the usb adapter from the PS2 slim and hooked it up to the computer, and I got similar (bad) results that were on the Pi. One controller doesn't work at all, and the other has button issues. So I am assuming the USB adapter is shit. The good news is my controllers work okay, and I don't have to buy some off ebay, the bad news is that I need to order another USB adapter....
