    How to theme Menu and Options?
    themetheme helptheme making
    17 Posts 7 Posters 4.8k Views
    • HexH
      Hex
      I noticed that the theme I am using doesnt theme the Menu and Options accessed through Start and Select. How can I achieve this?
      DarkWolfD B 2 Replies Last reply Reply Quote 0
      • DarkWolfD
        DarkWolf @Hex
        @Hex These menues are hardcoded (the style of them) and are not themeable!
        System: Raspberry 3 Model B, RetroPie 4.2.1
        Storage: 16gb Micro SD, 64gb USB Drive
        Theme: Updated NBBA
        Documentation solves many problems: https://retropie.org.uk/docs/
        HexH 1 Reply Last reply Reply Quote 0
          backstander @Hex
          @Hex
          Here is some more discussion on this subject:
          https://retropie.org.uk/forum/topic/5591/how-to-change-button-icons-done
          • HexH
            Hex @DarkWolf
            @DarkWolf That is what I was afraid of. Time to dive into code
            DarkWolfD 1 Reply Last reply Reply Quote 0
            • HexH
              Hex @backstander
              @backstander I am talking about the menu/options windows that open. not the help bar
              • DarkWolfD
                DarkWolf @Hex
                @Hex Good luck with this
                Edit: If your code is stable and clean make sure to submit a PR to the main branch
                Theme: Updated NBBA
                • E
                  EctoOne
                  Someone mentioned in another thread that he cloned the main branch and changed the colors in the code. And i think someone else said that they have it on their ToDo list to make it themeable with themes. But i can't find the threads and don't know how far progress is made yet.
                  • HexH
                    Hex @EctoOne
                    @EctoOne said in How to theme Menu and Options?:
                    Changing colors of Menu text is actually easy. Font is difficult as it originates from theme while color is hard coded
                    • E
                      EctoOne @Hex
                      @Hex Yeah, but like I said someone was able to change the hardcoded colors. And from what I remember it was pretty easy to do. It was some sort of Xbox style theme where the menu was blackish with green text I think. At the time there was so much work done on different versions of Emulationstation so I never tried it myself (because I hate the white menu too) and I forgot to bookmark it. And like I said, I can't find it now, because I'm to stupid or the search function is bad.
                      • HexH
                        Hex @EctoOne
                        @EctoOne, @backstander posted the link above. I guess this is the one you are looking for.
                        • E
                          EctoOne @Hex
                          @Hex No, it isn't. Your question was asked before in another thread and someone posted an answer with a screenshot of his build with the black options menu.
                          • AlexMurphyA
                            AlexMurphy Banned @EctoOne
                            @EctoOne Is it this guy you are thinking of? https://retropie.org.uk/forum/topic/8977/xcade-revived/2
                            • E
                              EctoOne @AlexMurphy
                              @AlexMurphy Yes, but the wrong thread. I looked through his posts and found the right one. https://retropie.org.uk/forum/topic/9171/xcade-custom-theme/20
                                Someone actually managed to theme the help and options menu. @jacobfk20 did it a few months ago.
                                He got it to be a themeable element and merged it into his ES fork, which also contains grid view.
                                Here it is: https://github.com/jacobfk20/EmulationStation/tree/Release-beta
                                But sadly he hasn't been active in a while, and the last thing he did on this fork was in December
                                AlexMurphyA E 2 Replies Last reply Reply Quote 1
                                • AlexMurphyA
                                  AlexMurphy Banned @lilbud
                                  @lilbud Jeez, that font really annoys me for some reason... but I'm liking the grid- view. Might be a pain scrolling through hundreds of mame titles but would work well on systems with a compact library.
                                  • TMNTturtlguyT
                                    TMNTturtlguy
                                    Here is a link to the code in that build for changing font. I don't know how to implement this, but if someone is up to the challenge it could be interesting:
                                    menu font
                                    I could only find a hard code change from 2012 that changed the color of the menu.
                                    • E
                                      EctoOne @lilbud
                                      @lilbud Huh, interesting. I've seen this before but never noticed that it had the themeable menu. Probably because at that point I wasn't interested in that feature and the lack of updates. Maybe someone of our other great coders can adapt his changes.
