WiFi speed test
Not sure if this is the beat place to post this but us there a way to test WiFi speeds? Primarily for using Kofi
@rockthe99 It's a musical place for sure. Not sure why you need to utilise Kofi Annan, but sounds interesting.
You can test network speed from a terminal via SSH. For example http://lifehacker.com/how-to-test-your-internet-speed-with-a-terminal-command-1364123567
@rockthe99 There is a
speedtester.net
addon for Kodi, There is also a speed tester utility in theIndigo
tool. Not sure if I can post links to unofficial Kodi addons, so I won't. A quick google will get you what you need. -
@AlexMurphy you assume he wants kodi not kofi? :)
@spruce_m00se Ha! Kofi is good. I prefer Jodi, myself.
@AlexMurphy kofi in the morning is just what you need after a long night with jodi
