    Input for specific ROM not working
    cfgconfigsconfiginputsnes
    25 Posts 3 Posters 7.4k Views
      mediamogul Global Moderator @abrad1212
      @abrad1212
      Deleting that file should at least put the controls back inline with the defaults. It's bizarre that it doesn't, but I'm sure it's all related. I'm afraid I'm out of ideas for the time being. I'll keep thinking on it though.
        abrad1212
        Alright my PS4 controller is all screwed up on the menu now too. I'm going to be and will figure this out tommorow
          pjft @abrad1212
          @abrad1212 apologies for asking, but what happens if you do re-configure the controls in emulationstation?
          Could it be that the original settings are messed up and that's what's causing this across all emulators?
          I didn't seem to find the details on what was failing with the original controls setup that caused you to have to manually edit the configurations?
            abrad1212
            @pjft said in Input for specific ROM not working:
            Yeah I actually remapped the controller and that is what screwed up the controls on the main menu. So the menu controls are working now.
              abrad1212
              @mediamogul When I change the controls in Sony_Computer_Entertainment_Wireless_Controller.cfg it changes the controls in games, but doesn't change the controls for the menu so I think that is good.
