    Grey Box for Emulation settings disappears after a while.
    retropie 4.2retroarchemulationretropiemenu
    30 Posts 7 Posters 8.5k Views
    • RedBatmanR
      RedBatman
      Okay so I learned yesterday that the grey box I'm talking about is Run Command. So yes Run command after awhile will go black, though I think it's more fair to say it goes to sleep. See for now it can take me going through over 10, sometimes 20 roms before the Run Command goes to sleep. Which like I said in a previous post it will affect Retropie setup and Raspberry Config, which is usually remedied by a keyboard press.
      I can tell that a lot of people here probably use thier scrapped game art as a splash screen and probably won't even notice anything. But if someone could test it out on there end and maybe see if it happens to them after a number or times, since I'm treating this as a minor software bug, which I imagine wouldn't bother most people. Still any help is appreciated.
        A Former User
        Can you post a video of what's going on and possibly your setup? It would help a lot.
        RedBatmanR 1 Reply Last reply Reply Quote 0
        • RedBatmanR
          RedBatman @A Former User
          @itsnitro Okay I should do that since I have said I would a few times already, also what exactly do you want to know of my setup like what types of emulators I'm using?
            A Former User
            @RedBatman Maybe the image you are using, the emulators, themes (they might do something) and what Grey Box you are talking about.
            • RedBatmanR
              @itsnitro The post I gave not too long ago about the grey box I'm talking about is Run Command, also what do you mean by image, sorry whIle Imy tech savvy when it comes to Linux I'm bit of a newbie.
              • RedBatmanR
                RedBatman
                I just found another topic from a year ago with my exact issue
                https://retropie.org.uk/forum/topic/2831/runcommand-dialog-before-game-sometimes-disappears
                Could this fix still work? If so how do I implement correctly?
                  meleu @RedBatman
                  @RedBatman You should provide details about your setup. Like that form in the read-this-first post.
                  EDIT: I've just realized that I asked for this info 4 days ago.
                  • RedBatmanR
                    RedBatman
                    Okay its a raspberry pi 3 b
                    Retropie 4.2.3
                    Emulation Station 2.19
                    Xbox 360 contoller
                    47inch lgtv
                    So how do I add something to cmdline.txt? Since I tried the fix in
                    and I don't think I'm doing it right.
                      meleu @RedBatman
                      @RedBatman If you started your RetroPie with 4.2 there's no need to do that workaround in /boot/cmdline.txt.
                      By the way, how did started in RetroPie. I mean, how did you got an SD card with RetroPie installed in it? Did you install the 4.2 or a previous version?
                      • RedBatmanR
                        RedBatman @meleu
                        @meleu Well funny thing is that I fixed it for now. And I installed it via Raspian Desktop the first time.
