    4-way control axis won't register using a Rockfire Serial to USB converter
    emulation statjoystick mappingamepad configjoystick controjoytick index
    1 Posts 1 Posters 774 Views
    • jamrom2J
      jamrom2
      Hi,
      I bought this Rockfire Serial Gameport to USB Converter...
      https://rockfire.com.tw/en/products/accessory/usb-accessory/7-rm-203-usb-nest-converter.html
      ... to use with Dosbox and my old CH Pro MACH I. ES sees it and allows me to configure it, but when I try to selected the right and down axis, it does not register the joystick movement/placement.
      It sees Left and Up just fine and uses 1- and 0-. The 2 buttons work fine. Is there any reason why I can't get right and down to register? It works fine in W10 and all checks good in the joystick calibration.
      Would be a treat to be able to use this old stick again for all my DOS games.
      Thanks in advance,
      Let me know if there is anything I need to post.
      Pi3
      Retropie 4.2
      JR.
