    Create a custom ES system able to launch games for many systems
    emulationstatiocustomisationscustom theme
    157 Posts 15 Posters 96.6k Views
      OMG! I'm loving this theme tweaking stuff!!!
      • Howitzer99H
        Howitzer99
        I'm still trying to fully understand the differences between the various config directories, but following along with the OP for setting up a Konani directory, I ended up getting it to work by editing my ~/.emulationstation/es_systems.cfg file instead of the one listed in /etc/emulationstation/ directory.
        Are the files in the ~/.emulationstation intended to be only for overrides, so essentially empty except for and local changes? I started with an existing image setup a few months ago, so while it's helpful for getting started, does add some confusion later on when trying to weed-out unnecessary files.
        melue, thanks for putting together this tutorial, very helpful, and thanks to UDB23 for the Mega Man vector, nice work!
        meleuM 2 Replies Last reply Reply Quote 2
          meleu @Howitzer99
          removed duplicated post (due to poor internet connection)
            meleu @Howitzer99
            @Howitzer99 said in Create a custom ES system able to launch games for many systems:
            Well, I thought it was the first place ES looks for es_systems.cfg ans, if not found, look in /etc/emulationstation. But if it's working as you're saying, one file complementing the other, it's great. I'll update the OP when I have a chance.
            By the way, Did you use the script to create the custom system's gamelist.xml? I'm curious to see if it's being useful to someone else. :-)
            Edit: post a screenshot of your custom ES system. ;-)
            • Howitzer99H
              Howitzer99
              meleu, I did run your "custom-system-autoscraper.sh", but when the Konami directory didn't showup in ES, I ended up running sscraper on the listed konami directory from the retropie-setup script. I'm seeing metadata listed, but probably from the sscraper.
              Sure, now that I know that it's working for creating a custom system, I'll start working on some custom ES system designs this week.
                meleu @Howitzer99
                @Howitzer99 I intentionally made it doesn't change any existing entry in the custom system's gamelist.xml. So, if you run it after sselph it won't do anything. (According to what you said this is not your case, I've putting this just for info ;-) ).
                I'm planning to write a script to simplify the symbolic link creation. This step can be pretty tedious and a script can help. Stay tuned!
                Cheers!
                cyperghostC Howitzer99H 2 Replies Last reply Reply Quote 1
                  cyperghost @meleu
                  @meleu I have boosted the fav launcher a bit now we can create FAV files via runcommand :)
                  https://retropie.org.uk/forum/topic/10971/dev-little-favorite-launcher-second-attempt-ready-for-testers
                  • Howitzer99H
                    Howitzer99 @meleu
                    @meleu I had some time to checkout your script for creating the gamelist.xml based on existing roms, and yes, it does work, and is pretty slick! Nice that its only reading existing metadata to create the list. I've never seen 'xmlstarlet' before, more reading to do.
                    How is the symbolic link program going? Please let me know if you want me to run some tests.
                    One thing I'm discovering is that I don't have the video previews setup for ES (working fine for Attract Mode). I have a bunch of video snaps and marquees, so I don't need to scrape my games again, only point to the existing files that Attract Mode is using. Do you know if anyone has created a script to embed the video and marquee data into an existing gamelist.xml file? I went through one post with almost 600 replies (somewhat fast), and didn't see a script to add these.
                    pjftP E meleuM 3 Replies Last reply Reply Quote 1
                      pjft @Howitzer99
                      @Howitzer99 There was a script by @Nismo, I think, using Powershell, I believe, that does that. If you search the forums for something like that, you'll get the gist of it. If you can't, do let me know (on the go at the moment). The script just adds the proper "video" tags to the gamelists, based on the rom name, and to a folder that you can change in the script. It does assume that the video name will be the same as the rom name. Oh, and it had some minor issues with game names that had "." in the middle, but you can fix those as one-offs.
                      • E
                        EctoOne @Howitzer99
                        @Howitzer99 Someone posted a tutorial on adding videos and marquees with regular expressions a few days ago but i can't find it for whatever reason.
                        But there is also a windows tool that can do what you want.
                        https://retropie.org.uk/forum/topic/9486/gengal-gamelist-xml-generator
                        Howitzer99H 1 Reply Last reply Reply Quote 0
                        • Howitzer99H
                          Howitzer99 @EctoOne
                          @EctoOne Thanks, I did see the Windows version, I should have prefaced the request that I'm looking for a linux script not windows.
                            pjft @Howitzer99
                            @Howitzer99 Check my post. I ran it on a Mac, and it's a terminal script. You just need to install PowerShell for Linux.
                            • Howitzer99H
                              Howitzer99 @pjft
                              @pjft Awesome, thanks, will checkout PowerShell as well.
                              GenGal definitely hits the request, thanks for the fast replies!
                                meleu @Howitzer99
                                Almost done. I had to be away from my computers in the last few days but now I'm back. I'm going to post about it here in a couple of days. ;-)
                                I'm making it create the link and the respective gamelist.xml entry at the same time. So, you will just have to run this tool to accomplish these two tasks.
                                • E
                                  EctoOne @meleu
                                  Is there a way to expand the script @meleu made for batch linking to have maybe the original system added as suffix in the link? I finally had some time to try this out and i ran into a problem when i tried to made just a SEGA system. Since i have all my Roms zipped, i ran into an issue with having the same filename inside my GameGear and MasterSystem folder. IDK if it is possible on linux but it would be great if i could links like gamename (europe)-gamegear.zip
                                  # in this example I'm creating links for every file in gameboy directory
                                  original_system="/home/pi/RetroPie/roms/gb"
                                  destination_system="/home/pi/RetroPie/roms/nintendo"
                                  while read -r file; do
                                    ln -s "$original_system/$file" "$destination_system/$file"
                                  done < <(ls "$original_system")
                                    meleu @EctoOne
                                    @EctoOne the link can have any name you want. You can batch all, and then manually create those with the same name.
                                    Or maybe wait a day or two and see the script I'm planning to release. ;-)
                                    TMNTturtlguyT 1 Reply Last reply Reply Quote 2
                                    • TMNTturtlguyT
                                      TMNTturtlguy @meleu
                                      @meleu oh my! I can't wait! This must be an impressive script! Can you confirm that it will link the rom and gamelist info all in one script command? I was going to use your script to populate all of my new systems in the theme today, but now I will have to wait to see what you have in store for us!
                                      meleuM 2 Replies Last reply Reply Quote 0
                                        meleu @TMNTturtlguy
                                        @TMNTturtlguy said in Create a custom ES system able to launch games for many systems:
                                        Confirmed!
                                        Wait a little, I'm at work now and planning to finish the script this evening. ;-)
                                        edit: I mean evening in Brazil.
                                        • Howitzer99H
                                          Howitzer99 @meleu
                                          @meleu,@pjft I just tried running GenGal, and yes it's working to add the missing video and marquees attributes to my gamelists. One problem is that it's completely overwriting the existing metadata, so how are people adding (back) the extra information that GenGal doesn't provide (game information, rating, plays, etc)?
                                          Between GenGal and FatMatch, looks like I'm sorted for now dealing with naming issues and creating the missing metadata attributes, just need to be able to merge and it should be good.
                                            pjft @Howitzer99
                                            @Howitzer99 as said, I don't use GenGal but a separate PowerShell script that adds those to the existing gamelists without deleting anything.
                                            Here's the thread:
                                            https://retropie.org.uk/forum/topic/6589/easy-way-to-add-video-and-marquees-tags-in-your-gamelist-for-video-support
