    Pi n00b needs help making PSX emulation work
    psx emulation
    2 Posts 2 Posters 548 Views
    • Z
      ZeroTX
      Hi guys,
      I'm a dumb newbie to the RetroPie, but I'm no tech novice. Nonetheless, I've been unsuccessful at getting the PSX emulation to work. I cannot even get a BIOS file that the system recognizes as valid. Furthermore, I downloaded Gran Turismo, which gives me two files, a .bin and a .cue. They also will not install. I'm installing via the web interface of retropie manager.
      Thanks for any guidance here... sorry of these questions are dumb and addressed somewhere else.
        backstander @ZeroTX
        @ZeroTX
        I don't think I've ever tried to install anything using the web interface.
        I usually transfer them over using something like FileZilla, WinSCP or Cyberduck.
        https://retropie.org.uk/docs/Transferring-Roms/#sftp
        Not, you might need to enable SSH before you can do this.
        https://retropie.org.uk/docs/SSH/#enable-ssh
        Also check your .cue file and make for dang sure that the .bin file referenced in the .cue file is the exact same case.
        https://retropie.org.uk/docs/PC-Engine/#pc-engine-cd
        (Linux filenames are case sensitive but Windows is not)
