    Rapid Fire / Auto Fire
    retropieauto firerapid fire
    7 Posts 3 Posters 9.0k Views
      chip
      Hi, I hope someone could help.
      I would like to know the way of setting rapid fire for raspberry pi. I am currently using a SNES control.
      Much obliged
      • AlexMurphyA
        AlexMurphy Banned @chip
        @chip Have you tried going into the RetroArch menus? Or do as I did and buy a controller with a TURBO button. Either way works.
          chip @AlexMurphy
          @AlexMurphy thank you for your reply. I am not familiar with the RetroArch. Could you give me some articles which I could refer to? Many thanks!
            mediamogul Global Moderator @chip
            @chip
            It can be done, but you have to choose a button that you would hold down to activate it. For a SNES controller, I would recommend using one of the shoulder buttons, but ultimately any button you choose will end up interfering with systems that need to make proper use that button. Ideally, this should be done with a button that is dedicated to nothing but the turbo function.
              chip @mediamogul
              @mediamogul it is possible to have auto fire for one button (e.g. B) only while another one (e.g. A) set as normal?
                @chip
                I'm afraid not.
                Edit: Not outside of the NES emulators anyway.
                  chip @mediamogul
                  @mediamogul thank you so mych m(_ _)m
