    Retropie-kernel panic-not syncing: vfs: unable to mount root fs on unknown-block(179,2)
    retropie 4.2kernel panicmicro sd
    24 Posts 9 Posters 17.3k Views
      jedimumbo
      Hello,
      I am getting: kernel panic-not syncing: vfs: unable to mount root fs on unknown-block(179,2) on my raspberry pi 3 running Retropie 4.2.
      Basically, everything was fine (used emulation station to play games) and then I made a genius move and removed my micro-sd card from my raspberry pi to put it in a samsung tablet to use (what? it's a boot drive?). Yes, I am a moron. I even deleted all of the files on the boot drive (G:) before I realized what I had done. Then, I tried to put it back in and got:
      "kernel panic-not syncing: vfs: unable to mount root fs on unknown-block(179,2)"
      I formatted the SD card and reimaged the SD card and the same happened. My computer stopped recognizing my SD card, so I bought a new one and imaged it just like I did from the get go and got the same message: "kernel panic-not syncing: vfs: unable to mount root fs on unknown-block(179,2)"
      I am imaging with win32 and using a PC. I don't currently have a USB keyboard. That was my next plan. Any ideas on how I can recover from this and get back to emulation station?
      Thank you.
      • simonsterS
        simonster
        Hi @jedimumbo
        Can you detail exactly how you are writing the image and which image you are using?
        Can you try completing the details in the read-this-first section above?
        Si
          jedimumbo
          I am writing using Win32DiskImager. It did work for a few weeks before I pulled my bonehead move. MicroSD reader into PC, use Win32DiskImager to Write to Micro SD.
          -Sorry.
          Pi Model or other hardware: Raspberry Pi 3 Model B
          Power Supply used: CanaKit 2.5A USB Power Supply with Micro USB Cable and Noise Filter
          RetroPie Version Used: 4.2
          Built From: retropie-4.2-rpi2_rpi3.img using Win32DiskImager
          USB Devices connected: MIcrosoft Xbox controller- wireless
          Controller used: See above.
          Error messages received: kernel panic-not syncing: vfs: unable to mount root fs on unknown-block(179,2)
          Log found in /dev/shm/runcommand.log (if relevant): ? Cannot get to this?
          Guide used: https://retropie.org.uk/docs/First-Installation/
          File: ?
          Emulator: Emulation Station
          Attachment of config files: ?
          How to replicate the problem: Boot it up by plugging it in.
          • simonsterS
            simonster
            Thanks for that,
            If you aren't getting any issues as the Win32DiskImager step, then the first step I would try would be to redownload the image and try writing it to a known good SD card (to rule out a dodgy SD card).
            Once you've imaged the card, do you get to the installation script for RetroPie open on first boot, or does it error immediately?
            Si
              jedimumbo
              Well... I did what you said. Which I had indeed done prior. And, now we're up and running. I don't know what I messed up on first, but thank you for asking me to do it again, because I'm back in business!
              • mr315M
                mr315
                Please! My English is bad. But this is also my problem.
                My pack is:
                Raspberry pi 3 v2
                Samsung 64gb
                Retropie 4.2
                Using Win32DiskImager
                Not connected USB
                Error messages received: kernel panic-not syncing: vfs: unable to mount root fs in unknown-block (179,2)
                Downloaded in the official Retropie page
                I tried with a Sandisk 8gb card, but nothing changed
                Tried to partition the 64GB card, but I got the same result
                Win32DiskImager displays an error about the image being corrupted. But I saw the same error and everything happens well.
                I hope you have understood me =)
                • jonnykeshJ
                  jonnykesh @mr315
                  @mr315 Just follow the advice given above. Re-download the image and burn it onto the card again. It worked for him, why wouldn't it work for you?
                  mr315M 1 Reply Last reply Reply Quote 0
                  • mr315M
                    mr315 @jonnykesh
                    @jonnykesh , I do not know. Tried several times.
                    I tried partitioning the SD and with a different SD... =(
                    Downloaded it through Chrome and Internet Explorer.
                    I will try a download manager later.
                    jonnykeshJ 2 Replies Last reply Reply Quote 0
                    • jonnykeshJ
                      jonnykesh @mr315
                      @mr315 Really odd. If you post exactly what you are doing and what software you are using to write the image to the card maybe someone will see where the problem is.
                      • jonnykeshJ
                        jonnykesh @mr315
                        @mr315 try this:
                        If your error message ends with 2, like this:
                            Kernel panic-not syncing: VFS: unable to mount root fs on unknown-block(179,2)
                        it is likely that the problem is caused by an update bug. The fix involves switching that 2 into a 6:
                            Start the Raspberry holding the Shift key.
                            Click the Edit config (e) button or press e.
                            Click the cmdline.txt tab or press the right arrow on the keyboard.
                            Replace:
                            root=/dev/mmcblk0p2
                        with
                            root=/dev/mmcblk0p6
                            Click OK and then press escape on the keyboard to proceed with the boot sequence.
                        Your Pi should now boot fine.
                        • mr315M
                          mr315
                          @jonnykesh , I format SD with "SD Formatter" -- or partition with 32gb with "Fat32Formatter" or other, but i dont remember now.
                          Download the image on "retropie.org.uk/download/";
                          Uncompressed with WinRar;
                          Write the image with "Win32DiskImager" on my sd.
                          I plug the card into the Raspberry and plug it in
                          ps: unzipping by 7zip generates an error that does not allow me to write the image.
                          And the keyboard does not work on the screen in question
                          • jonnykeshJ
                            jonnykesh @mr315
                            @mr315 The /boot partition can be read from a windows computer. Plug the SD card into a Win PC and edit the cmdline.txtfrom there.
                            mr315M 2 Replies Last reply Reply Quote 0
                            • mr315M
                              mr315 @jonnykesh
                              @jonnykesh Ok
                              • mr315M
                                mr315 @jonnykesh
                                @jonnykesh
                                The error now changed the end of "179,2" to "179,6". Nothing but.
                                • jonnykeshJ
                                  jonnykesh @mr315
                                  @mr315 Try using a program called etcher to write to the card. Link https://etcher.io/
                                  It takes a bit longer but it checks the image.
                                    StevieJoe360
                                    Hello,
                                    I have a theory, I'm not quite sure, but I heard somewhere that a Raspberry Pi 3 can only use up to 32 GB on an SD/MicroSD card, if it's higher than that you have to do something different. I know I'm being very vauge(?) here, but I don't remember all the details. I suggest you look up something like "raspberry pi 3 64gb sd card." Hope this helps, but if not... Remember, it's just a theory, A GAME THEORY!! (Sorry, I had to.)
                                    TMNTturtlguyT herb_fargusH 2 Replies Last reply Reply Quote 0
                                    • TMNTturtlguyT
                                      TMNTturtlguy @StevieJoe360
                                      @steviejoe360 this is not true, I have run several 128gb sd cards.
                                      • herb_fargusH
                                        herb_fargus administrators @StevieJoe360
                                        @steviejoe360 said in Retropie-kernel panic-not syncing: vfs: unable to mount root fs on unknown-block(179,2):
                                        What my crazy relative says right before they quote something they saw on their Facebook feed.
                                        • mr315M
                                          mr315 @jonnykesh
                                          @jonnykesh Thaks!
                                          I tested with "H2testw" and found that the 64GB SDXC is fake. But the 8GB is not and it happened the same. I'll buy one like a friend's. If the error persists, can it be the image or the raspberry?
                                          • jonnykeshJ
                                            jonnykesh @mr315
                                            @mr315 Where did you purchase the card from? Unfortunately there are a lot of fakes about. They all tend to be 4/8GB spoofing they are 64/128.
