    PS3 controller not recognized in CPS roms
    cpscontroller
    6 Posts 3 Posters 1.7k Views
    • F
      fabrice83
      Hi,
      I have installed Retropie 4.2 on RPi 3B and it works great.
      I have one little problem when I want to play with CPS rom (I have set them in fba folder...):
      the original PS3 controller isn't recognized under game (i.e. 1941, only keyboard works)
      may I missed something about config for this type game...
      PS3 controller works perfectly (bluetooth) in other emulators I have tried.
      Thanks for your help.
        chavatar
        Hi. If you're using pifba emulator (not lr-fbalpha) you may well have the same problem I had: https://retropie.org.uk/forum/topic/10519/pifba-and-wireless-ps3-controller
        • F
          fabrice83
          Hi,
          Thanks.
          I have forgotten to say that I had to use pifba emulator because no rom works when using lr-fbalpha...
          Beretta9B 1 Reply Last reply Reply Quote 0
          • Beretta9B
            Beretta9 @fabrice83
            @fabrice83 https://github.com/retropie/retropie-setup/wiki/FinalBurn-Alpha
            Get the correct romset for lr-fbalpha and the games will work.
            Retro Gamer Supreme
            • F
              fabrice83
              I will try to download correct roms and keep you informed
              • F
                fabrice83
                Hi,
                Finally, it works...
                I have downloaded correct romset and all works perfectly...
