    How to restart ES from a script?
    scriptessystems.cfgrestart
    111 Posts 5 Posters 41.3k Views
      meleu @cyperghost
      @cyperghost said in How to restart ES from a script?:
      @meleu
      Yes It's working with D-Pad A and B
      Really neat! :-) It seems to be a cool RetroPie feature, because if you launch the script directly from command line you can't use joystick for that.
      pkill -n emulationstatio always kills the newest process that the short version what my script exactly does. With all advantages and disadvantages - but the shortest script ;)
      Maybe we can make a video like this below replacing pumpkin by emulationstation:
        cyperghost @meleu
        @meleu Is this always the same pumpkin? I think a pumpkin always got's seven lives.
          meleu @cyperghost
          I think one is a binary, two or three are scripts, and the others were launched in an infinite loop inside some of those scripts.
            mediamogul Global Moderator @meleu
            @meleu
            What about Schrödinger's pumpkin?
            • TMNTturtlguyT
              TMNTturtlguy
              @meleu @cyperghost I tried to create the restart function as a separate choice from the menu, thus you first pick an option for which config file to load and then choose to restart. I tested with several of the variations of the restart command and each time I get similar results. The script works fine, but after running it, the start/quit menu runs an auto restart, no different than when the restart command is within the actual config change function. I am at a loss, like charlie brown waiting for the great pumpkin to appear :)
                meleu @TMNTturtlguy
                @TMNTturtlguy what's the version of your RetroPie-Setup? It must be 4.2.8+
                • TMNTturtlguyT
                  TMNTturtlguy @meleu
                  @meleu I am not at my pi right now, but i updated again about 12 hours ago, so it is the current version as of then.
                    cyperghost
                    Added new possibilities to ES RESTART THREAD
                    meleuM TMNTturtlguyT 2 Replies Last reply Reply Quote 0
                      meleu @cyperghost
                      @cyperghost Wow! We're looking like a bunch of murderers... There are many threads showing that there are many ways to kill EmulationStation. And I suspect the most promising is this one.
                      • TMNTturtlguyT
                        TMNTturtlguy @cyperghost
                        I just checked the thread and I am not clear what edits you made today? We have gone through so many ways to kill (per @meleu) that i can't keep what codes are what, and what new possibilities you added/modified.
                          cyperghost @meleu
                          @meleu That looks really promising ... But AS you know I am not a scraper. Indeed the caurosel view is fine. Maybe in not a far future all databases are setted to SQL and then it is easier to exchange ready scraped Databases. What do you think?
                          @TMNT in the thread are all working scripts listed inkl. how to and version numbering
