    FM Sound for Master System games...
    smsfm sound
    5 Posts 2 Posters 4.2k Views
      goombakid
      Is there a way to get FM sound from any SMS emulator on SMS games? I know Phantasy Star and Double Dragon have FM sound and I was hoping to be able to get that through Retropie.
      • fabio78F
        fabio78
        Yes, you have to change the default MS emulator from lr-picodrive to lr-genesis-plus-gx, then switch FM sound ON in the core options via Retroarch menu (Select+X).
        The caveat is that lr-genesis-plus-gx doesn't emulate Master System as good as the Picodrive because it's optimised to run Genesis/MD first. As a consequence, you will notice that scrolling isn't as smooth and the image a little stretched and blurry. I wish Picodrive had the FM option, but it is what it is, and I still stick with it.
        • fabio78F
          fabio78
          Btw, Kenseiden and R-Type sound amazing in FM.
            goombakid @fabio78
            @fabio78 Thanks! I forgot that R-Type had FM sound as well. I'm gonna have a go at it later tonight.
            • fabio78F
              fabio78
              Here's a list off all games that support FM sound:
              http://segaretro.org/FM_Sound_Unit
