    Sound was working, now nothing. Occasionally works, then cuts out. ES Volume always resets to 0.
    no soundvolume 0es volumevolume reset
    1 Posts 1 Posters 556 Views
      TSDAdam
      My bartop build was working just fine, sound and everything else. Then one day sound just stopped completely.
      I've since changed from the 3.5mm jack to a USB soundcard (and did all the necessary to set it as default sound device).
      Occasionally I can turn it all on and sound works straight away, but then sound can cut-out mid game. When it does stop (or doesn't work to begin with), if I go into the sound settings in ES the volume is 0. I can change it up, but as soon as I go back in, it's 0 again.
      I'm pretty sure it's not my speakers or amp, as I can't see why it would affect the volume level in the software.
      My setup is as follows:
      • RasPi 3.
      • DVI monitor driven by HDMI port and HDMI > DVI converter.
      • 3.5mm jack and/or USB sound through small, powered amp and speakers.
      • xin-mo USB controller.
