ultimarc aimtrak problem
I have 2 aimtrack lightguns, I use them with advmame 3.4
They work quite well even if some games works better than others. Yesterday, while my friends were playing, the guns stopped working and now I have a strage behavior: the guns seem to have a delay when I point to the screen; the cursor moves very slow to a point (which is not the one I'm pointing to). Same behavior for both guns.
In retropie application Gunconf I can set them as usually, they work well in calibration mode, so I guess It's a mame/retroarch problem..
Any hint? -
Your setup might give some clues. It is strange that everything was working and not now. Be sure to fill out all the required information listed at https://retropie.org.uk/forum/topic/3/read-this-first. Also, please detail the conditions in play when the guns stopped working and what you did to get them working again.
problem solved: someone switched from advmame 3.4 to advmame 1.4
the problem is when you start a game, moving the gun triggers the retroarch menu where you can change the default emulator, is there a way to avoid this?
@mediamogul i prefer to set it to use a keyboard only. That way someone can still change it if they need to.
Nice. That's a great middle ground solution.
