    (SOLVED) Retropie Beginner needs advices ! ;) (Gamepads not Detected)
    controllersnot detected4.2
    12 Posts 4 Posters 9.7k Views
    • KiirokunK
      Kiirokun
      Hello everyone !!
      I got my first Raspberry pie Zero some days ago, and i'm stuck with a problem : i tried to play, but the retropie doesn't detect my Gamepads / controllers !
      I tried with 3 of them, but there is no result, it works only with my keyboard...
      I downloaded the 4.2 version of Retropie !
      Pi Model or other hardware: (B, B+, 2 B, 3, X86 PC etc..) : RP Zero
      Power Supply used: Phone Charger 5v 1A
      RetroPie Version Used (eg 3.6, 3.8.1, 4.1 - do not write latest): 4.2
      USB Devices connected: Keyboard
      Controller used: Retrolink usb gamecube controller, and some chinese low cost NES controllers.
      How to replicate the problem: Trying to configure a controller.
      Thanks for your help !
      rbakerR 2 Replies Last reply Reply Quote 0
      • rbakerR
        rbaker @Kiirokun
        @Kiirokun Please post all the information in https://retropie.org.uk/forum/topic/3/read-this-first. In particular, what power supply?
        • KiirokunK
          Kiirokun
          Whoops sorry, i Edited it ! Thank you !
          • rbakerR
            rbaker @Kiirokun
            @Kiirokun I believe the problem lies with your power supply. Phone chargers are not recommended for use as power supplies but they may work and the device may boot. However, start doing some work and add a few peripherals and your 1A charger is unlikely to be up to it. Take a look at
            https://www.raspberrypi.org/help/faqs/#powerReqs and read at the bottom of the list - recommended 1.2A. Some phone chargers are not regulated for use in powering devices. You could find unpredictable behavior happening. The official 2.5A psu is good for all things pi and gives you lots of headroom.
            • O
              ortsac
              I agree with the assessment. Phone chargers are not stable and when they are overloaded they cannot keep up with the demands and then you will experience voltage dropouts. Majority of the problems that are encountered in this forum, especially for first time users, are: inadequate power supply and/or the power supply cables are not suited for Rpi use.
              • KiirokunK
                Kiirokun
                Oww thank you rbaker and ortsac !
                I think you're right, but it's incredible to think that just a little difference of power can do that !
                I'll try with a better one !
                • KiirokunK
                  Kiirokun
                  Hello there !
                  Sadly the problem is not the power supply, i got suited one and my controllers are still not detected...
                  Do you have an other idea ? Thank you for replying.
                  • O
                    ortsac
                    After you power it up, how far does it go when it boots up? What do you see on the screen? Need a little more details on the problem....
                    • KiirokunK
                      Kiirokun
                      Well, when i power it up, there is a classic screen with a raspberry on the top-left corner, a list of processes scroll down with a green "OK" for each, then after 5 seconds a screen with the logo "Retropie" appears during 15 seconds, then the list reappears and continue scrolling down, then the "Emulation station" screen appears, and finally i'm on a screen with a banner "retropie" in the middle, just below a "configuration" banner, and on the bottom- left corner there is 3 options "menu" "select" and "choose", i already tried to plug in several controllers but they are not detected, even if i do "configure input", my keyboard is the only one working.
                      • I have to plug my keyboard out and in to make the Pi detect it once powered up.
                      • On my Pi there is : a Micro USB to USB for the Power and for the USB HUB, a Micro HDMI to HDMI, a MicroSD card, and that's it !
                      Thanks for the reply
                        Melvin.FoX
                        Have you tried to reimage your sd card and install it from scratch? You could also try to reinstall everything from RetroPie-Setup script. Maybe there is something wrong with some drivers or some additional software. Use your keyboard, get into retropie setup, then go to main and core plugins and find whether there is something about controllers or usb drivers. Try to update/reinstall it before doing reimage.
                        • KiirokunK
                          Kiirokun
                          Hey ! I don't know what 'Scratch' is, i'm really a beginner ! ^^"
                          I'm actually looking for some controllers options, i'm in the "raspberry pi software configuration tool", but i think i don't have to change something !
                          • KiirokunK
                            Kiirokun
                            Okay everyone, thank you for your help, i did it !!
                            Now, i know that a Cheap USB HUB is not a good idea ! x)
                            I bought a new one, not really more expensive, and Tada !
                            Thanks for everything !
