    Help with Pizero, mame4all and Berryboot
    1 Posts 1 Posters 652 Views
      dominator
      Hi,
      I have an arcade project that is running fine with the following components/programs:
      Pi model b
      i-pac usb interface for the buttons, joysticks
      19" dvi monitor
      berryboot booting to pimame straight into mame4all.
      It runs great, boots into mame4all fairly quickly with no problems. though I can't remember how I set it up! I think I found a squashed pimame image and started from there.
      So here is my problem; I want to remove the berryboot startup and upgrade to a pizero. Is it possible to extract the squashed image and somehow get it working on its own? I have tried to backup the image, but it wont boot up.
      I have also tried out the latest retropie on the zero, but this does not seem to work with the ipac interface. Although I really like retropie, setting it up does not seem all that easy, especially when it comes to adding roms and configuring controllers. I really only want to boot straight to mame.
      Cheers,
      Dom.
