    [SOLVED]Need help starting Bluetooth on RPi 3B
    bluetoothconnectionwii u proraspberry pi 3b
    4 Posts 1 Posters 6.5k Views
    • fellegF
      felleg
      [SOLVED, see post 4]
      I'm trying to connect my Wii U Pro controller to my Raspberry Pi, but I'm having issues. I think they are due to the fact my Bluetooth daemon was not started. I am using a Raspberry Pi 3B, which should in principle contain bluetooth out of the box. However, two things seem to suggest bluetooth is turned off:
      --- in the terminal---
      When I type bluetoothctl, the console shows [bluetooth]#, but then I cannot write anything unless I press ctrl-C to escape the application. I've searched online, and this seems to be because bluetooth is not working properly.
      -- In the pixel desktop ---
      I go to the applications menu -> Preferences -> Bluetooth manager. This pop-up the following message: "Bluez daemon is not running, blueman-manager cannot continue. This probably means that there were no Bluetooth adapters detected or Bluetooth daemon was not started." The pop-up then closes, and nothing happens after that.
      To resolve this issue, I tried to do the following:
      sudo apt-get update
      sudo apt-get dist-update
      sudo apt-get upgrade
      tells me everything is up-to-date
      sudo apt-get install pi-bluetooth blueman
      tells me the applications were already installed and are still up-to-date
      systemctl status bluetooth
      this gives me:
      ● bluetooth.service - Bluetooth service
      Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled)
      Active: failed (Result: exit-code) since Wed 2017-07-12 22:03:40 EDT; 4min 23s ago
      Docs: man:bluetoothd(8)
      Process: 25055 ExecStart=/usr/lib/bluetooth/bluetoothd (code=exited, >status=203/EXEC)
      Main PID: 25055 (code=exited, status=203/EXEC)
      To start bluetooth manually, I tried both
      sudo systemctl start bluetooth
      and
      sudo /etc/init.d/bluetooth start
      which respectively give
      Job for bluetooth.service failed. See 'systemctl status bluetooth.service' and 'journalctl -xn' for details.
      and
      [....] Starting bluetooth (via systemctl): bluetooth.serviceJob for bluetooth.service failed. See 'systemctl status bluetooth.service' and 'journalctl -xn' for details.
      failed!
      I don't know what to try anymore... This raspberry pi should have bluetooth, but it's really as if there's no way to start it! Anyone dares to help? Thanks in advance...
      Pi Model or other hardware: 3B (I know this because I can do wifi without a dongle)
      Power Supply used: (If using a Pi): Canakit 5V supply
      RetroPie Version Used: 4.2, I think
      USB Devices connected: A USB Key, a USB Keyboard, A Hori Pro FC controller. Trying to connect a bluetooth Wii U Pro controller.
      Error messages received: "Bluez daemon is not running, blueman-manager cannot continue. This probably means that there were no Bluetooth adapters detected or Bluetooth daemon was not started."
      Log found in /dev/shm/runcommand.log (if relevant): no log
      Guide used: https://github.com/RetroPie/RetroPie-Setup/wiki/Wii-U-Pro-Controller
      File: n/a
      Emulator: n/a
      Attachment of config files: none
      fellegF 1 Reply Last reply Reply Quote 1
      • fellegF
        felleg @felleg
        By the way, the Wii u pro controller doesn't even seem to be recognized via USB. I am certain this is a legitimate official controller. Does this also affect other Wii u pro users? Is it Bluetooth only?
        • fellegF
          felleg
          Quick update: When I do hcitool scan and press the sync button on the Wii U Pro controller, the terminal outputs:
          Scanning ...
          9C:e^:35:0A:FD:6D Nintendo RVL-CNT-01-UC
          The Pi seems to see the device!! However, I am still unable to start bluetoothctl of the Bluetooth manager to actually pair it.
          • fellegF
            felleg
            [SOLVED]
            What was causing the issue was the ps3 bluetooth drivers, which I realized were disabling the standard bluetooth on the device.
            Thanks to this thread: https://www.raspberrypi.org/forums/viewtopic.php?f=28&t=148305&start=100
            The solution was to simply uninstall the PS3 drivers from the retropie_setup menu.
