    Mausberry Shutdown Script Doesn't Save Metadata
    mausberry
    251 Posts 10 Posters 107.9k Views
      cyperghost
      @meleu I agree - I think version 1.59 is a final version now.
      But please correct your ghostbin bash... there are small errors in... $emucall isn't definated - it should rather be $emupid
      @barrymossel It doesn't matter if you use 1.58 or 1.59. The logic is the same only the style of coding is different.
      Feel free to upgrade to v1.59 -- Final version
        meleu @cyperghost
        @cyperghost said in Mausberry Shutdown Script Doesn't Save Metadata:
        fixed! thanks!
        emucall is emucall and emupid is emupid. ;-)
          cyperghost @meleu
          @meleu
          No problem brother. I corrected it but used only emupid as variable :)
          But it is better to repost code according to your latest changes. So there is one version 1.59 around
          About using variables? You see I'm avoiding these and use just a bunch of them...
          Is there any difference? Speed up? Memory usage?
          I know it's better for clear code reading.... but is that effcient?
            barrymossel
            Sorry guys, I was busy drinking last night so I didn't test yet. Probably won't this evening. Will test later this weekend, but I am sure it works with the two of you working on it :)
              barrymossel
              Yup, seems to work. Thanks guys!
              • lostlessL
                lostless
                @meleu @cyperghost Hey, somthing has happened. The script no longer works in retroarch. This is recent as I just updated and a week ago it worked. so Kodi it kills, and will shutdown emulation station properly if its open, but will no longer kick retroarch back to emulation station to exit. It just says terminated and shuts down without saving meta data. Looks like it just gives up and does the old way of shutting down. also @cyperghost , my reset on my nespi no longer works with retro arch, kodi is fine, because of what ever has happened. WHY DID I UPDATE!!!!! LOL
                  meleu @lostless
                  @lostless can you please try this approach here?: https://retropie.org.uk/forum/topic/12895/ensuring-es-gracefully-finish-and-save-metadata-in-every-system-shutdown
                  • lostlessL
                    lostless @meleu
                    @meleu I’ll take a look when I get home. Just To Verify, this is what I have running in my script. Is this the most up to date?
                    #!/bin/bash
                    # Terminate any emulatorcall!
                    # This works just for RetroPie!
                     emucall="$(sed -n 4p /dev/shm/runcommand.info | tr -d '\\"' | tr '^$[]*.()|+?{}' '.')"
                            if [[ -n "$emucall" ]]; then
                                emupid="$(pgrep -f "$emucall")"
                                pkill -P "$emupid"
                                kill "$emupid"
                                sleep 4
                            fi
                    cyperghostC meleuM 2 Replies Last reply Reply Quote 0
                      cyperghost @lostless
                      @lostless Please use the approach @meleu posted...
                      The coding is the same but you don't need to modify the shutdown script itself!
                        meleu @lostless
                        @lostless please, when posting a code like that put it beetween codeblocks. More info here: http://commonmark.org/help/
                        • lostlessL
                          lostless
                          Looks like I’m missing the “wait”at the end compared to the script I use for the reset button. I’ll add it in and see if it helps. The issue I’m having though is not meta data related. As I said. When in ES, it funtions fine. It’s just when in retroarch that it no longer exits back to ES. Kodi is fine. It was working fine until yesterday.
                          • lostlessL
                            lostless @meleu
                            @meleu heres the script im using now, same issue
                            #!/bin/bash
                            # If there's an emulator running, we need to kill it and go back to ES
                                pkill -P "$emupid"
                                kill "$emupid"
                                wait "$emupid"
                                sleep 5 # maybe it can be lesser
                            fi
                            and errors im getting trying to exit out of retroarch
                            pkill: killing pid 1 failed: Operation not permitted
                            pkill: killing pid 2 failed: Operation not permitted
                            ./exit.sh: line 9: kill: `': not a pid or valid job spec
                            ./exit.sh: line 10: wait: `': not a pid or valid job spec
                              meleu @lostless
                              @lostless are you able to access your raspi via SSH while running an emulator?
                              If yes, I would like to ask you to do this:
                              1. launch a game.
                              2. access your raspi via SSH.
                              3. perform this command:
                              bash -x /path/to/the/emulator/killer/script.sh 2> debug.txt
                              1. The command above generates the debug.txt file. Post this file on ghostbin or something similar.
                              Thanks.
                              • lostlessL
                                lostless @meleu
                                @meleu https://ghostbin.com/paste/qa5ph
                                Just want to say thanks for all your help.
                                • lostlessL
                                  lostless
                                  @meleu Sorry, looks like copying from nano cut a lot off text. heres a good copy
                                  https://ghostbin.com/paste/q9zsm
                                  meleuM 2 Replies Last reply Reply Quote 1
                                    meleu @lostless
                                    @lostless Thanks for this. I've found the problem. The runcommand.sh script changed a bit 3 days ago. I just have to adapt my Regular Expression and make it stronger. Wait a little, I'll try to sort it on our script.
                                      meleu @lostless
                                      @lostless I made my tests on a shell where there's no RetroPie installed and I believe it will work fine. But, you know, sh!t happens...
                                      Try this version, please (feedback would be appreciated):
                                      #!/bin/bash
                                      emucall="$(sed -n 4p /dev/shm/runcommand.info | tr -d '\\"' | tr '^$[]*.()|+?{}' '.' | sed 's/[^ ]*=[^ ]* //g')"
                                          pkill -P "$emupid"
                                          kill "$emupid"
                                          wait "$emupid"
                                      fi
                                      maybe I'll try to simplify that crazy line with a simpler regex later... ;-)
                                      lostlessL 1 Reply Last reply Reply Quote 1
                                      • lostlessL
                                        lostless @meleu
                                        @meleu Its working in retroarch now im going to patch in into my mauseberry shutdown script!!!!!!!!!!!!!! YOU ARE THE MAN
                                        But kodi is not working
                                        https://ghostbin.com/paste/uqo6e
                                        debug of kodi not exiting.
                                        not a big deal if kodi does not work. Just kind of want my reset button to be the end all to go back to ES.
                                          meleu @lostless
                                          @lostless said in Mausberry Shutdown Script Doesn't Save Metadata:
                                          Here it goes another version, trying to get kodi too:
                                              emupid="$(pgrep -f "$emucall" | tr '\n' ' ')"
                                              pkill -P "$(echo $emupid | tr ' ' ',')"
                                              kill "$emupid"
                                              wait "$emupid"
                                          fi
                                          • lostlessL
                                            lostless
                                            @meleu it works!!!!!! but now it looks like i blew out the gpio pin for my reset button. NOOOOOOOOOOOOOOOOO. That what i get for using a different build without gpio setup. GPIO DANGEROUS TO USE if not setup?
