    shell scripting topic
    shellshell scriptprogramming
    191 Posts 10 Posters 96.1k Views
    • SanoS
      Sano @meleu
      @meleu That I can answer !
      Actually it's in the very doc you mention :
      https://www.gnu.org/software/bash/manual/bash.html#Shell-Arithmetic
      Constants with a leading 0 are interpreted as octal numbers. A leading ‘0x’ or ‘0X’ denotes hexadecimal. Otherwise, numbers take the form [base#]n, where the optional base is a decimal number between 2 and 64 representing the arithmetic base, and n is a number in that base. If base# is omitted, then base 10 is used. When specifying n, the digits greater than 9 are represented by the lowercase letters, the uppercase letters, ‘@’, and ‘_’, in that order. If base is less than or equal to 36, lowercase and uppercase letters may be used interchangeably to represent numbers between 10 and 35.
        meleu @Sano
        @sano whoops! Didn't catch those little words 😅
        Thanks Sano-san. And yeah, I learned more tricks!
        SanoS 1 Reply Last reply Reply Quote 1
        • SanoS
          Sano @meleu
          @meleu Just FYI, you could just have used date +%-H ;)
          Glad to see you here again BTW !
            meleu @Sano
            @sano ouch! Looks like I need RTFM some more...
            From the date man page:
                   By default, date  pads  numeric  fields  with  zeroes.   The  following
                   optional flags may follow '%':
                   -      (hyphen) do not pad the field
            Thanks again, Sanso-sensei!
            • SanoS
              Sano @meleu
              @meleu I really deserve no special credit for this, I just remembered something like this existed, probably had to use it in the past, too :)
                cyperghost
                A common mistake is often made by using grep.
                It is often told that grep finds a total of all search strings within a text file due the -c switch. That is total nonsense .... -c just counts lines
                So we miss
                hello hello hello hello
                hello
                grep -c hello
                2
                We use a small hack ;)
                Better is to use the -o option is will show occourences of search string listed in newline and now we pipe to wc -l ... and count lines again - now we catched them all ;)
                hello
                grep -o hello | wc -l
                5
                  cyperghost
                  @meleu
                  EDIT BEGIN
                  I think I found a good solution with pure bash
                  But maybe some knows a better one ;)
                  val=${#Unix[@]}
                  for ((i=0; i<$val; i+=1)); do
                  EDIT END
                  Is there something that can be made easier (more efficient) than this script?
                  I want to merge two arrys
                  A1=(1 2 3)
                  A2=(one two there)
                  the result should be A3
                  A3=(1 one 2 two 3 three)
                  It works with this script.
                  But first... I want to avoid any counters (if possible)
                  Do you know a nice trick to count up values {0..6} works only with fixed characters not as variable. So {0..6} is fine {0..$arraysize} not
                  #!/bin/bash
                  # A small script to show how to merge two arrays
                  # with alternating values (exp. for creating arrays for dialogs)
                  # Example Array
                  Unix=("Debian" "Red hat" "Ubuntu" "Suse" "Fedora" "UTS" "OpenLinux")
                  Shell=("bash" "csh" "jsh" "rsh" "ksh" "rc" "tcsh")
                  # Check if both arrays got some size
                  [[ ${#Unix[@]} -eq ${#Shell[@]} ]] || exit 1
                  echo "Both arrays got same size -- Proceed"
                  val=$((${#Unix[@]}-1))
                  echo $val
                  for i in $(seq 0 $val); do
                      echo "Merging ${Unix[$i]} and ${Shell[$i]}"
                      UnixShell+=("${Unix[$i]}" "${Shell[$i]}")
                  done
                  echo "${UnixShell[@]}"
                    meleu @cyperghost
                    @cyperghost both methods are perfectly valid (using a for to iterate through all items).
                      cyperghost @meleu
                      @meleu thanks for the feedback -- I appreciate it ;)
                      Come on ... take a look in the MAME RoW now - if you have time ;)
                      • hiulitH
                        hiulit
                        FYI, I'll release a new version of RetroPie Shell Script Boilerplate soon-ish.
                        This is a template for building shell scripts for RetroPie, with some helper functions, dialogs, etc.
                        My little contributions to the RetroPie project:
                        • Shell-Script-Boilerplate
                        • Fun-Facts-Splashscreens
                        • Limit-Last-Played-Games
                        • hiulitH
                          hiulit
                          Well, here it is! A new version of RetroPie Shell Script Boilerplate.
                          This is a template for building shell scripts for RetroPie.
                          I've added examples of the following dialog boxes:
                          • --infobox
                          • --yesno
                          • --msgbox
                          • --menu
                          All the dialogs can be found at utils/dialogs.sh
                          I've also moved some functions to utils/base.sh.
