    shell scripting topic
    shellshell scriptprogramming
    191 Posts 10 Posters 99.3k Views
    • hiulitH
      hiulit @meleu
      Well, actually, I used the same line @meleu is using in his generate-launching-images.sh:P See:
      https://github.com/meleu/generate-launching-images/blob/c55e61ee0066438068cf5b72c62430337bb1e3d5/generate-launching-images.sh#L416
      xml_path="/theme/view[contains(@name,'detailed')]/textlist/fontPath"
      I don't know if we could have a more "standard" search function for fonts, because some themes have different fonts and it would be difficult to know which one is the "primary" font. I'm not into EmulationStation theming so I don't know if there's a predominant font that we could use.
      Also, @cyperghost , if I understood you correctly, you though about searching for the font based on the theme's name? (e.g Pixel theme -> pixel.ttf)
      Because, for what I see, there isn't a "standardized" naming convention on font naming for themes.
      The default to Carbon's font it's nice, yeah! ;)
      My little contributions to the RetroPie project:
      • Shell-Script-Boilerplate
      • Fun-Facts-Splashscreens
      • Limit-Last-Played-Games
      • hiulitH
        hiulit
        I would like to try to run Fun Facts Splashscreens on system's shutdown (or startup) but I don't have any clue about where to start looking. Any hint?
        I've been looking at this thread https://retropie.org.uk/forum/topic/4836/emulationstation-shutdown-script/ and I've been able to add a line in /opt/retropie/supplementary/emulationstation/emulationstation.sh to launch es-fun-facts-splashscreens.sh and it works, but I don't think this is right place to do it nor the way to do it.
        The place isn't right because, I think, the script should run either on system's startup or shutdown, as @Zigurana mentioned, not when EmulationStation starts, restarts or shutdowns. It doesn't make sense, because the splashscreens shows before EmulationStation starts.
        And the way to do it isn't right because I don't like that, for this script to be launched, you have to edit some "core" files.
        Is there any way to launch a script either on system's startup or shutdown?
          meleu @hiulit
          @hiulit said in shell scripting topic:
          This file will be overwritten after the next ES update. Then, you're right, it's not the best script to tweak...
          At shutdown it's a bit tricky. I did this for my trick to gracefully finish ES and save metadata in every system shutdown
          At start it's pretty simple: /etc/rc.local. And in my opinion your script can safely be placed here but you need to remove that command to show the image in the end.
          It's a good place because the script can be setted to run in background (add & in the end of line that is calling your script). I think the current splashscreen to be displayed will be the previous generated one, but your script would be generating a new splash for the next boot. ;-)
          hiulitH 1 Reply Last reply Reply Quote 2
          • hiulitH
            hiulit @meleu
            @meleu I've added the script to etc/rc.local but it seems that there's something wrong with the $home variable. I get this error:
            sed: cant' read /root/.emulationstation/es_settings.cfg: No such file or directory
            Instead of getting /home/pi as $home, it gets root, so the script doesn't work.
            hiulitH 1 Reply Last reply Reply Quote 0
            • hiulitH
              hiulit @hiulit
              @hiulit If I launch the script adding -H -u pi it works, but I don't think it's the best way to do it...
                meleu @hiulit
                @hiulit If a launch the script adding -H -u pi it works, but I don't think it's the best way to do it...
                IMHO it's perfectly acceptable and also a really good way to do it. ;-)
                Of course if we evolve this method, this config (adding the script call in rc.local) won't be made manually, and then we can get the username to use.
                • hiulitH
                  hiulit @meleu
                  @meleu But then, does it make sense to keep using this?
                  user="$SUDO_USER"
                  [[ -z "$user" ]] && user="$(id -un)"
                  home="$(eval echo ~$user)"
                  Because that's what's getting root as $home when the script is launched in /etc/rc.local.
                  We could then just do home="/home/pi", don't you think?
                  Because adding the user -H -u pi like this removes the dynamism of the function (getting the user dynamically), right?
                    meleu @hiulit
                    user="$SUDO_USER"
                    Yes. Keeping this in the script makes sense because the user can use it at any moment, right?
                    Does it happen even when using sudo -H -u pi ...???
                    Sorry if I misunderstood you, but you want to avoid to remove dynamism by hardcoding home=/home/pi? Sounds weird for me.
                    I would consider what we have until now like a proof-of-concept script (kudos to you for working on this). Let's wait what the big boss will say about my proposal and take next steps based on his decision.
                    If he refuse, we can continue this project extra-officially. I'm just trying to say that what approach to use to launch the script at startup depends on that decision.
                      cyperghost @hiulit
                      No, we misunderstood ;)
                      If the theme CARBON looks like this
                      ./art/font-1.ttf and ./art/font-2.ttf
                      you can try to use ls *.ttf -R to find all fonts that are in the theme folder.
                      Then do a grep search with all fonts and give the most usefull hit the path to your $DEFAULT_FONT
                      Is it clear now? But maybe @meleu gots a better solution. I know it's bad to use lscommand for this action ;)
                      • hiulitH
                        hiulit @meleu
                        @meleu Ok, you're right! I didn't explain myself clearly, hehe! It sounds weird not wanting to hardcode sudo -H -u pi but wanting to hardcode home="/home/pi" instead :P Nonsense!
                        Now, I'm at home and I'm testing the script in an actual Raspberry Pi with RetroPie and I have a couple of things to comment:
                        • I've added sudo ~/es-fun-facts-splashscreens/es-fun-facts-splashscreens.sh & and it seems to work when I launch /etc/rc.local from the terminal, but not when the system boots up.
                        • I've tried adding -H -u pi and it doesn't seem to work.
                        This code worked perfectly! :D I didn't had imagemagick installed on this Raspberri Pi and the warning pop up, nice!
                        if ! which convert > /dev/null; then
                            echo "ERROR: The imagemagick package is not installed!"
                            echo "Please, install it with 'sudo apt-get install imagemagick'."
                            exit 1
                        fi
                        But I didn't had feh installed and the warning didn't pop up :(
                        if [[ -n "$DISPLAY" ]] && ! which feh  > /dev/null; then
                            echo "ERROR: The feh package is not installed!"
                            echo "Please, install it with 'sudo apt-get install feh'."
                            exit 1
                        fi
                        Maybe instead of && it should be || ?
                        Or maybe remove [[ -n "$DISPLAY" ]] and just leave if ! which feh > /dev/null ?
                        Anyways, the script works perfectly by itself and when launching /etc/rc.local from the terminal, but not when it's supposed to be launched in /etc.rc.local at startup.
                        • hiulitH
                          hiulit @cyperghost
                          @cyperghost Ok, but how would we know which is "the best hit"? Based on what?
                            cyperghost @hiulit
                            @hiulit Well the xml in the root of the theme or keywords like "mainfont=font-1.ttf".... That are just suggestions.
                            Or you write an identifier.txt so you say: theme, font
                            # Example file
                            Carbon, system.ttf
                            IO, mainfont.ttf
                            hiulitH 1 Reply Last reply Reply Quote 1
                            • hiulitH
                              hiulit @cyperghost
                              @cyperghost don't get me wrong! I really appreciate the feedback :)
                              I think we can try to find a generic method to get fonts if we squeeze our minds together
                              • hiulitH
                                hiulit
                                What do you think about this code?
                                I want to add a line in /etc/rc.local to launch a script.
                                Also, I want to check if that line is already in /etc/rc.local.
                                Additionally, I want to check if /etc/rc.local has the needed exit 0 at the end (in case the user removed it).
                                The latter is totally optional.
                                # If the user mistakenly removed "exit 0", add it at the end of "/etc/rc.local".
                                function check_safe_exit_boot_script() {
                                    if [[ "$(tail -n1 /etc/rc.local)" != "exit 0" ]]; then
                                        sed -i -e '$i \exit 0\' "/etc/rc.local"
                                    fi
                                # Get the line that launches script at boot.
                                # $SCRIPT_DIR="/home/pi/es-fun-facts-splashscreens".
                                function check_boot_script() {
                                    grep "$SCRIPT_DIR" "/etc/rc.local"
                                # Add the line to launch script in "/etc/rc.local"
                                function add_boot_script() {
                                    sed -i -e '$i \\n'"$home"'/es-fun-facts-splashscreens/es-fun-facts-splashscreens.sh &\n' "/etc/rc.local"
                                # Check if the line that launches the script is already in "/etc/rc.local"
                                # If it's not, add it.
                                [[ -z "$(check_boot_script)" ]] && add_boot_script
                                  cyperghost @hiulit
                                  @hiulit Well I think as setup.sh this is possible. Withwget path/to/your/github/es-funfacts.sh a (half)automated installation shouldbe possible ;)
                                  About the correct font ... there is surly a generic solution. But what about adding just a path to a font via command line parameter?
                                  So you have es-funfacts.sh /path/to/font.ttf
                                  1. Find automatically the correct font
                                  2. If 1 fails, try to use Carbon font (as default theme)
                                  3. If there is a parameter available then 1 and 2 are ignored
                                  • hiulitH
                                    hiulit
                                    Hello my fellow nerds! :P
                                    First piece of code is this one:
                                    function is_arm() {
                                        uname -m | grep -q "arm"
                                    I'm trying to detect if the device is arm based. If not, I'm gussing it's x86 based .
                                    And then I'm using this other piece of code to get the screen resolution.
                                    arm based systems and x86based systems have different methods to get the screen resolution. And that's what I've come up with.
                                    function get_screen_resolution_x() {
                                        if is_arm; then
                                            fbaset -s | cut -dx -f1
                                        else
                                            xdpyinfo | awk -F '[ x]+' '/dimensions:/{print $3}'
                                        fi
                                    function get_screen_resolution_y() {
                                        if is_arm; then
                                            fbaset -s | cut -dx -f2
                                        else
                                            xdpyinfo | awk -F '[ x]+' '/dimensions:/{print $4}'
                                        fi
                                    mituM meleuM 2 Replies Last reply Reply Quote 1
                                      mitu Global Moderator @hiulit
                                      @hiulit If your intention is to detect whether the user is running under a desktop environment (X) or not, then I wouldn't use the architecture of the kernel to determine that, but something more simple like testing if the DISPLAY env is available or something like this.
                                      Running on an ARM board doesn't mean the user's session is not running under Pixel and vice-versa.
                                        meleu @hiulit
                                        First of all, we would be able to be more helpful if you say what exactly you want to do. Anyways, here are some thoughts about what you asked...
                                        I would use the system.sh scriptmodule for this or at least get some inspiration from its code.
                                        Example using the existent code:
                                        . $HOME/RetroPie-Setup/scriptmodules/helpers.sh
                                        . $HOME/RetroPie-Setup/scriptmodules/system.sh
                                        get_platform
                                        echo "$__platform"
                                        Or get inspiration from the function starting on this line of code to write your own function.
                                        The $__platform variable is one of these:
                                        rpi1 rpi2 rpi3 odroid-c1 odroid-c2 imx6 odroid-xu tinker x86
                                        (...) get the screen resolution.
                                        I agree with @mitu above.
                                          grant2258 Banned
                                          probably a useless one but might come in helpful if people dont know use -- in a command line if it has special characters and bash will ignore the special characters.
                                          pi@retropie:~ $ touch -- +1.txt
                                          pi@retropie:~ $ less -- +1.txt
                                          pi@retropie:~ $ less +1.txt
                                          Missing filename ("less --help" for help)
                                          • hiulitH
                                            hiulit
                                            Thanks to all! You were very useful :)
                                            Sorry @meleu (and @mitu ) if I wasn't more precise.
                                            The problem I'm facing is that I want to get the screen resolution to create launching images accordingly to that size, but the way I found to get it differs from, for example, my Raspberry Pi (arm) and my VM running Pixel (x86).
                                            I think I like @meleu 's idea of using $__platform.
