    How to delete Hi-Res Texture Packs on RetroPie for N64
    n64 texture pac
    4 Posts 3 Posters 1.9k Views
      Bulletproof
      Hello all!
      First and foremost I apologize if I missed something in the Forum rules section.
      Long story short I've slowly gotten my RetroPie up and running well for N64 games.
      I installed some hi res texture packs. One of the hi-res packs was terrible. I've since removed the original files from the following location.
      /home/pi/.local/share/mupen64plus/hires_texture
      However, each time I load the rom the Hi Res pack continues to be used.
      The only way I've been able to disable it is by changing the following settings.
      Save texture cache to hard disk.
      txSaveCache = False
      If I keep it at False the Rom no longer loads the texture pack.
      I guess my question is how can I remove whatever cache'd info is saved on the Hard disk which isn't located in /home/pi/.local/share/mupen64plus/hires_texture as I'd like to change this setting back to True.
      Here is my current setup
      Pi Model or other hardware: P3
      Power Supply used: 2.5
      RetroPie Version Used: 4.2
      Built From: Pre Made
      USB Devices connected: 2 Generic N64 USB Controllers
      Controller used:
      Error messages received:
      Emulator: mupen64plus-GLideN64-highres
      Attachment of config files:
      Config file
      Mupen64Plus Configuration File
      This file is automatically read and written by the Mupen64Plus Core library
      [Audio-OMX]
      Version = 1
      OUTPUT_PORT = "1"
      ShowFPS = True
      fontSize = 14
      fontColor = "1F1F1F"
      EnableLegacyBlending = True
      txHiresEnable = True
      Frequency which is used if rom doesn't want to change it
      DEFAULT_FREQUENCY = 33600
      Swaps left and right channels
      SWAP_CHANNELS = False
      Audio Output Frequncy mode (when NATIVE_MODE=false): 0 = Rom Frequency, 1 ROM Frequency if supported (HDMI only), 2 = Standard frequency < Rom Frequency, 3 = Standard frequency > Rom Frequency, [N] Force output frequency
      DEFAULT_MODE = 0
      [Audio-SDL]
      Mupen64Plus SDL Audio Plugin config parameter version number
      Version = 1
      Size of primary buffer in output samples. This is where audio is loaded after it's extracted from n64's memory.
      PRIMARY_BUFFER_SIZE = 16384
      Fullness level target for Primary audio buffer, in equivalent output samples. This value must be larger than the SECONDARY_BUFFER_SIZE. Decreasing this value will reduce audio latency but requires a faster PC to avoid choppiness. Increasing this will increase audio latency but reduce the chance of drop-outs.
      PRIMARY_BUFFER_TARGET = 2048
      Size of secondary buffer in output samples. This is SDL's hardware buffer. The SDL documentation states that this should be a power of two between 512 and 8192.
      SECONDARY_BUFFER_SIZE = 1024
      Audio resampling algorithm. src-sinc-best-quality, src-sinc-medium-quality, src-sinc-fastest, src-zero-order-hold, src-linear, speex-fixed-{10-0}, trivial
      RESAMPLE = "speex-fixed-4"
      Volume control type: 1 = SDL (only affects Mupen64Plus output) 2 = OSS mixer (adjusts master PC volume)
      VOLUME_CONTROL_TYPE = 1
      Percentage change each time the volume is increased or decreased
      VOLUME_ADJUST = 5
      Default volume when a game is started. Only used if VOLUME_CONTROL_TYPE is 1
      VOLUME_DEFAULT = 80
      Synchronize Video/Audio
      AUDIO_SYNC = False
      [Core]
      Mupen64Plus Core config parameter set version number. Please don't change this version number.
      Version = 1.009999
      Draw on-screen display if True, otherwise don't draw OSD
      OnScreenDisplay = False
      Use Pure Interpreter if 0, Cached Interpreter if 1, or Dynamic Recompiler if 2 or more
      R4300Emulator = 2
      Disable compiled jump commands in dynamic recompiler (should be set to False)
      NoCompiledJump = False
      Disable 4MB expansion RAM pack. May be necessary for some games
      DisableExtraMem = False
      Increment the save state slot after each save operation
      AutoStateSlotIncrement = False
      Activate the R4300 debugger when ROM execution begins, if core was built with Debugger support
      EnableDebugger = False
      Save state slot (0-9) to use when saving/loading the emulator state
      CurrentStateSlot = 0
      Path to directory where screenshots are saved. If this is blank, the default value of ${UserConfigPath}/screenshot will be used
      ScreenshotPath = "/home/pi/RetroPie/roms/n64"
      Path to directory where emulator save states (snapshots) are saved. If this is blank, the default value of ${UserConfigPath}/save will be used
      SaveStatePath = "/home/pi/RetroPie/roms/n64"
      Path to directory where SRAM/EEPROM data (in-game saves) are stored. If this is blank, the default value of ${UserConfigPath}/save will be used
      SaveSRAMPath = "/home/pi/RetroPie/roms/n64"
      Path to a directory to search when looking for shared data files
      SharedDataPath = "/opt/retropie/configs/n64"
      Delay interrupt after DMA SI read/write
      DelaySI = True
      Force number of cycles per emulated instruction
      CountPerOp = 0
      Use alternate VI timing (-1=Game default, 0=Don't use alternate timing, 1=Use alternate timing)
      ViTiming = -1
      Modify the default count per scanline(-1 or 0=Game default)
      CountPerScanline = -1
      Disable speculative precompilation in new dynarec
      DisableSpecRecomp = True
      [CoreEvents]
      Mupen64Plus CoreEvents config parameter set version number. Please don't change this version number.
      Version = 1
      SDL keysym for stopping the emulator
      Kbd Mapping Stop = 27
      SDL keysym for switching between fullscreen/windowed modes
      Kbd Mapping Fullscreen = 0
      SDL keysym for saving the emulator state
      Kbd Mapping Save State = 286
      SDL keysym for loading the emulator state
      Kbd Mapping Load State = 288
      SDL keysym for advancing the save state slot
      Kbd Mapping Increment Slot = 0
      SDL keysym for resetting the emulator
      Kbd Mapping Reset = 290
      SDL keysym for slowing down the emulator
      Kbd Mapping Speed Down = 291
      SDL keysym for speeding up the emulator
      Kbd Mapping Speed Up = 292
      SDL keysym for taking a screenshot
      Kbd Mapping Screenshot = 293
      SDL keysym for pausing the emulator
      Kbd Mapping Pause = 112
      SDL keysym for muting/unmuting the sound
      Kbd Mapping Mute = 109
      SDL keysym for increasing the volume
      Kbd Mapping Increase Volume = 93
      SDL keysym for decreasing the volume
      Kbd Mapping Decrease Volume = 91
      SDL keysym for temporarily going really fast
      Kbd Mapping Fast Forward = 102
      SDL keysym for advancing by one frame when paused
      Kbd Mapping Frame Advance = 47
      SDL keysym for pressing the game shark button
      Kbd Mapping Gameshark = 103
      Joystick event string for stopping the emulator
      Joy Mapping Stop = "J0/,J1/"
      Joystick event string for switching between fullscreen/windowed modes
      Joy Mapping Fullscreen = ""
      Joystick event string for saving the emulator state
      Joy Mapping Save State = "J0/,J1/"
      Joystick event string for loading the emulator state
      Joy Mapping Load State = "J0/,J1/"
      Joystick event string for advancing the save state slot
      Joy Mapping Increment Slot = ""
      Joystick event string for taking a screenshot
      Joy Mapping Screenshot = ""
      Joystick event string for pausing the emulator
      Joy Mapping Pause = ""
      Joystick event string for muting/unmuting the sound
      Joy Mapping Mute = ""
      Joystick event string for increasing the volume
      Joy Mapping Increase Volume = ""
      Joystick event string for decreasing the volume
      Joy Mapping Decrease Volume = ""
      Joystick event string for fast-forward
      Joy Mapping Fast Forward = ""
      Joystick event string for pressing the game shark button
      Joy Mapping Gameshark = ""
      [Input-SDL-Control1]
      Mupen64Plus SDL Input Plugin config parameter version number. Please don't change this version number.
      version = 2
      Controller configuration mode: 0=Fully Manual, 1=Auto with named SDL Device, 2=Fully automatic
      mode = 2
      Specifies which joystick is bound to this controller: -1=No joystick, 0 or more= SDL Joystick number
      device = 0
      SDL joystick name (or Keyboard)
      name = "Generic USB Joystick "
      Specifies whether this controller is 'plugged in' to the simulated N64
      plugged = True
      Specifies which type of expansion pak is in the controller: 1=None, 2=Mem pak, 5=Rumble pak
      plugin = 2
      If True, then mouse buttons may be used with this controller
      mouse = False
      Scaling factor for mouse movements. For X, Y axes.
      MouseSensitivity = "2.00,2.00"
      The minimum absolute value of the SDL analog joystick axis to move the N64 controller axis value from 0. For X, Y axes.
      AnalogDeadzone = "4096,4096"
      An absolute value of the SDL joystick axis >= AnalogPeak will saturate the N64 controller axis value (at 80). For X, Y axes. For each axis, this must be greater than the corresponding AnalogDeadzone value
      AnalogPeak = "32768,32768"
      Digital button configuration mappings
      DPad R = "hat(0 Right)"
      DPad L = "hat(0 Left)"
      DPad D = "hat(0 Down)"
      DPad U = "hat(0 Up)"
      Start = "button(9)"
      Z Trig = "button(8)"
      B Button = "button(4)"
      A Button = "button(5)"
      C Button R = "button(1)"
      C Button L = "button(3)"
      C Button D = "button(2)"
      C Button U = "button(0)"
      R Trig = "button(7)"
      L Trig = "button(6)"
      Mempak switch = ""
      Rumblepak switch = ""
      Analog axis configuration mappings
      X Axis = "axis(0-,0+)"
      Y Axis = "axis(1-,1+)"
      input_enable_hotkey_btn = "button(9)"
      input_exit_emulator_btn = "button(8)"
      [Input-SDL-Control2]
      version = 2
      mode = 2
      device = 1
      name = "DragonRise Inc. Generic USB Joystick "
      plugged = True
      plugin = 2
      mouse = False
      Start = "button(9)"
      Mempak switch = ""
      [Input-SDL-Control3]
      version = 2
      mode = 2
      device = -1
      name = ""
      plugged = True
      plugin = 2
      mouse = False
      Start = "button(9)"
      L Trig = ""
      Mempak switch = ""
      [Input-SDL-Control4]
      version = 2
      mode = 2
      device = -1
      name = ""
      plugged = False
      plugin = 1
      mouse = False
      DPad R = ""
      DPad L = ""
      DPad D = ""
      DPad U = ""
      Start = ""
      Z Trig = ""
      B Button = ""
      A Button = ""
      C Button R = ""
      C Button L = ""
      C Button D = ""
      C Button U = ""
      R Trig = ""
      L Trig = ""
      Mempak switch = ""
      X Axis = ""
      Y Axis = ""
      [UI-Console]
      Mupen64Plus UI-Console config parameter set version number. Please don't change this version number.
      Version = 1
      Directory in which to search for plugins
      PluginDir = "./"
      Filename of video plugin
      VideoPlugin = "mupen64plus-video-GLideN64.so"
      Filename of audio plugin
      AudioPlugin = "mupen64plus-audio-omx.so"
      Filename of input plugin
      InputPlugin = "mupen64plus-input-sdl.so"
      Filename of RSP plugin
      RspPlugin = "mupen64plus-rsp-hle.so"
      [Video-General]
      Fullscreen = False
      ScreenWidth = 640
      ScreenHeight = 480
      If true, activate the SDL_GL_SWAP_CONTROL attribute
      VerticalSync = False
      If true, use correct aspect ratio, if false, stretch to fullscreen
      AspectRatio = True
      [Video-GLideN64]
      configVersion = 17
      bilinearMode = 1
      CacheSize = 50
      EnableFBEmulation = True
      UseNativeResolutionFactor = 1
      Crop resulted image (0=disable, 1=auto crop, 2=user defined crop)
      CropMode = 0
      Crop width pixels from left and right of resulted image (in native resolution)
      CropWidth = 0
      Crop height pixels from top and bottom of resulted image (in native resolution)
      CropHeight = 0
      Enable/Disable MultiSampling (0=off, 2,4,8,16=quality)
      MultiSampling = 0
      Screen aspect ratio (0=stretch, 1=force 4:3, 2=force 16:9, 3=adjust)
      AspectRatio = 1
      Swap frame buffers (0=On VI update call, 1=On VI origin change, 2=On buffer update)
      BufferSwapMode = 0
      Max level of Anisotropic Filtering, 0 for off
      MaxAnisotropy = False
      Enable color noise emulation.
      EnableNoise = True
      Enable LOD emulation.
      EnableLOD = True
      Enable hardware per-pixel lighting.
      EnableHWLighting = False
      Use persistent storage for compiled shaders.
      EnableShadersStorage = True
      Make texrect coordinates continuous to avoid black lines between them. (0=Off, 1=Auto, 2=Force)
      CorrectTexrectCoords = 0
      Render 2D texrects in native resolution to fix misalignment between parts of 2D image.
      EnableNativeResTexrects = False
      Do not use shaders to emulate N64 blending modes. Works faster on slow GPU. Can cause glitches.
      Enable writing of fragment depth. Some mobile GPUs do not support it, thus it made optional. Leave enabled.
      EnableFragmentDepthWrite = True
      Use GLideN64 per-game settings.
      EnableCustomSettings = True
      Copy auxiliary buffers to RDRAM
      EnableCopyAuxiliaryToRDRAM = False
      Enable N64 depth compare instead of OpenGL standard one. Experimental.
      EnableN64DepthCompare = False
      Disable buffers read/write with FBInfo. Use for games, which do not work with FBInfo.
      DisableFBInfo = True
      Read color buffer by 4kb chunks (strict follow to FBRead specification)
      FBInfoReadColorChunk = False
      Read depth buffer by 4kb chunks (strict follow to FBRead specification)
      FBInfoReadDepthChunk = True
      Enable color buffer copy to RDRAM (0=do not copy, 1=copy in sync mode, 2=copy in async mode)
      EnableCopyColorToRDRAM = 2
      Enable depth buffer copy to RDRAM (0=do not copy, 1=copy from video memory, 2=use software render)
      EnableCopyDepthToRDRAM = 2
      Enable color buffer copy from RDRAM.
      EnableCopyColorFromRDRAM = False
      Texture filter (0=none, 1=Smooth filtering 1, 2=Smooth filtering 2, 3=Smooth filtering 3, 4=Smooth filtering 4, 5=Sharp filtering 1, 6=Sharp filtering 2)
      txFilterMode = 0
      Texture Enhancement (0=none, 1=store as is, 2=X2, 3=X2SAI, 4=HQ2X, 5=HQ2XS, 6=LQ2X, 7=LQ2XS, 8=HQ4X, 9=2xBRZ, 10=3xBRZ, 11=4xBRZ, 12=5xBRZ), 13=6xBRZ
      txEnhancementMode = 0
      Deposterize texture before enhancement.
      txDeposterize = False
      Don't filter background textures.
      txFilterIgnoreBG = False
      Size of filtered textures cache in megabytes.
      txCacheSize = 100
      Use high-resolution texture packs if available.
      Allow to use alpha channel of high-res texture fully.
      txHiresFullAlphaChannel = False
      Use alternative method of paletted textures CRC calculation.
      txHresAltCRC = False
      Enable dump of loaded N64 textures.
      txDump = False
      Zip textures cache.
      txCacheCompression = True
      Force use 16bit texture formats for HD textures.
      txForce16bpp = False
      txSaveCache = True
      Path to folder with hi-res texture packs.
      txPath = "/home/pi/.local/share/mupen64plus/hires_texture"
      File name of True Type Font for text messages.
      fontName = "FreeSans.ttf"
      Font size.
      fontSize = 14
      Font color in RGB format.
      Enable bloom filter
      EnableBloom = False
      Brightness threshold level for bloom. Values [2, 6]
      bloomThresholdLevel = 4
      Bloom blend mode (0=Strong, 1=Mild, 2=Light)
      bloomBlendMode = 0
      Blur radius. Values [2, 10]
      blurAmount = 10
      Blur strength. Values [10, 100]
      blurStrength = 20
      Force gamma correction.
      ForceGammaCorrection = False
      Gamma correction level.
      GammaCorrectionLevel = 2
      Show FPS counter.
      ShowFPS = True
      Show VI/S counter.
      ShowVIS = False
      Show percent counter.
      ShowPercent = False
      Counters position (1=top left, 2=top center, 4=top right, 8=bottom left, 16=bottom center, 32=bottom right)
      CountersPos = 8
      [Video-Rice]
      LoadHiResTextures = True
      Frame Buffer Emulation (0=ROM default, 1=disable)
      FrameBufferSetting = 0
      Frequency to write back the frame buffer (0=every frame, 1=every other frame, etc)
      FrameBufferWriteBackControl = 1
      Render-to-texture emulation (0=none, 1=ignore, 2=normal, 3=write back, 4=write back and reload)
      RenderToTexture = 0
      Control when the screen will be updated (0=ROM default, 1=VI origin update, 2=VI origin change, 3=CI change, 4=first CI change, 5=first primitive draw, 6=before screen clear, 7=after screen drawn)
      ScreenUpdateSetting = 7
      Force to use normal alpha blender
      NormalAlphaBlender = False
      Use a faster algorithm to speed up texture loading and CRC computation
      FastTextureLoading = False
      Use different texture coordinate clamping code
      AccurateTextureMapping = True
      Force emulated frame buffers to be in N64 native resolution
      InN64Resolution = False
      Try to reduce Video RAM usage (should never be used)
      SaveVRAM = False
      Enable this option to have better render-to-texture quality
      DoubleSizeForSmallTxtrBuf = False
      Force to use normal color combiner
      DefaultCombinerDisable = False
      Enable game-specific settings from INI file
      EnableHacks = True
      If enabled, graphics will be drawn in WinFrame mode instead of solid and texture mode
      WinFrameMode = False
      N64 Texture Memory Full Emulation (may fix some games, may break others)
      FullTMEMEmulation = False
      Enable vertex clipper for fog operations
      OpenGLVertexClipper = False
      Enable/Disable SSE optimizations for capable CPUs
      EnableSSE = True
      Use GPU vertex shader
      EnableVertexShader = False
      If this option is enabled, the plugin will skip every other frame
      SkipFrame = False
      If enabled, texture enhancement will be done only for TxtRect ucode
      TexRectOnly = False
      If enabled, texture enhancement will be done only for textures width+height<=128
      SmallTextureOnly = False
      Select hi-resolution textures based only on the CRC and ignore format+size information (Glide64 compatibility)
      LoadHiResCRCOnly = True
      Enable texture dumping
      DumpTexturesToFiles = False
      Display On-screen FPS
      ShowFPS = True
      Widescreen hack
      WideScreenHack = False
      Use Mipmapping? 0=no, 1=nearest, 2=bilinear, 3=trilinear
      Mipmapping = 2
      Enable, Disable or Force fog generation (0=Disable, 1=Enable n64 choose, 2=Force Fog)
      FogMethod = 1
      Force to use texture filtering or not (0=auto: n64 choose, 1=force no filtering, 2=force filtering)
      ForceTextureFilter = 2
      Primary texture enhancement filter (0=None, 1=2X, 2=2XSAI, 3=HQ2X, 4=LQ2X, 5=HQ4X, 6=Sharpen, 7=Sharpen More, 8=External, 9=Mirrored)
      TextureEnhancement = 6
      Secondary texture enhancement filter (0 = none, 1-4 = filtered)
      TextureEnhancementControl = 0
      Color bit depth to use for textures (0=default, 1=32 bits, 2=16 bits)
      TextureQuality = 0
      Z-buffer depth (only 16 or 32)
      OpenGLDepthBufferSetting = 16
      MultiSampling = 0
      Color bit depth for rendering window (0=32 bits, 1=16 bits)
      ColorQuality = 0
      OpenGL level to support (0=auto, 1=OGL_1.1, 2=OGL_1.2, 3=OGL_1.3, 4=OGL_1.4, 5=OGL_1.4_V2, 6=OGL_TNT2, 7=NVIDIA_OGL, 8=OGL_FRAGMENT_PROGRAM)
      OpenGLRenderSetting = 0
      Enable/Disable Anisotropic Filtering for Mipmapping (0=no filtering, 2-16=quality). This is uneffective if Mipmapping is 0. If the given value is to high to be supported by your graphic card, the value will be the highest value your graphic card can support. Better result with Trilinear filtering
      AnisotropicFiltering = 0
      edmaul69E L 2 Replies Last reply Reply Quote 0
        edmaul69 @Bulletproof
        @bulletproof you need to either post your config on a site like pastebin.com or for smaller configs you need to use code block. Put 3 backticks on the line above and below your settings. The backtick is the backwards apostrophe under the esc key. I am on my phone so i cant type a backtick to show you. It is impossible trying to read your config like this.
          Bulletproof
          Done!
          Here is my current # Mupen64Plus Configuration File
          https://pastebin.com/dRUJThuw
          • L
            ledhed @Bulletproof
            I came across this same problem today. I know this post is getting old, but hopefully this answer is useful to others who have the same problem.
            To clear the cached HiRes Textures, navigate to: /home/pi/.cache/mupen64plus/cache/
            delete the file: <ROM_Name>_HIRESTEXTURES.htc
            Where <ROM_Name> is the name of the ROM you want to clear the cached textures.
            Say for example you wanted to clear the high resolution textures for Super Mario 64,
            rm /home/pi/.cache/mupen64plus/cache/"SUPER MARIO 64_HIRESTEXTURES.htc"
            -LedHed
