    system view background issue
    theme helpsystem viewgamelist
    5 Posts 3 Posters 1.5k Views
    • paffleyP
      paffley
      Hi, I've noticed a fade/bleeding issue when exiting from a game - System view background is viewable before the gamelist view fades in?
      Latest build
      Instant transition
      Hope this helps.
      Regards,
      • Beretta9B
        Beretta9
        We need more details.
        Retro Gamer Supreme
          pjft
          Can you share a screenshot?
          Also, if you disable Power Savings in the "Other Settings" menu, does it still happen?
          Thanks.
          • paffleyP
            paffley
            Thanks guys...Power Savings was already disabled...I believe its the same issue @ruckage was having with the bleeding of the system view on the transition. I changed my carousel to horizontal and it stops doing it. I believe jdrassa has implemented a fix but not sure if its been merged into the official repo just yet?
            Regards,
            P.S I'll take a short video tomorrow and post it with the carousel in vertical mode and horizontal mode.
            I have a couple of themes almost ready for a release and need it to be 100% (my OCD ha!) :)
              pjft
              Oh.
              Got it.
              Yes, there's an issue with the new vertical carousel. As there hadn't been many themes with it yet, these hadn't really surfaced, but it sounds like it's the same.
              @jdrassa FYI in case there's any more info you need.
              Thank you.
