    Amiga and DosBox emulators not showing
    amiga uae4armamiga retropiedosbox
    33 Posts 11 Posters 7.2k Views
      gordonfreemanjr
      Hi eveyrone,
      as in the title:
      I'm aware that the problem has been tackled and commented on lots of times. Unfortunately, I can't seem to overcome my problem with existing forum posts and online guides. I'm not IT, the command line is a mystery to me, I have been given my Raspberry Pi as a gift and would never manage to build one on my own. Therefore, I need you, the People Who Understand, to explain things to me in an extremely simple manner, preferably instructing me step by step.
      I'm using a homemade Raspberry Pi, which is unconnectable to the Internet. One gamepad connected, a wireless keyboard connected, power supply: a wall USB cube (if that's a correct name for it).
      Regarding Amiga: I have:
      • checked for Amiga emulators; one is present: uae4arm,
      • created the "amiga" directory in "roms" folder;
      • transferred 2 games in .adf format there via a USB stick;
      • downloaded 3 kickstart roms (kick13.rom, kick20.rom, kick31.rom), renamed them as instructed and moved them to the "bios" folder.
        The Amiga emulator is not showing on the main screen. I have noticed that +start uae4arm.sh file, which I have noticed on a Youtube video, is NOT present in the "amiga" folder, which is not surprising as I have created it myself. I'm lost, I don't know what to do next.
      Regarding DosBox - I have:
      • created the "pc" folder in the "roms" directory,
      • moved few games there via a USB stick - no zips, only full game folders.
        The DosBox is either not showing on the main screen
      Please help & advise! Thank you.
      RPi 4 4GB
      Retropie v 4.7.1
      • wilenekW
        wilenek
        Did you install the emulators from retropie-setup?
        • I
          incunabula
          Why is it unable to connect to the internet? May be a problem if you don't have the right emulators installed. That may be the first thing we need to solve.
            gordonfreemanjr
            @wilenek said in Amiga and DosBox emulators not showing:
            As mentioned above, it wasn't me from the beginning - I have been given Retropie as a gift. I have not been involved in the installation and configuration process at all. All I know, NES, SNES, Megadrive, Arcade and Atari 2600 emulators work flawlessly.
            @incunabula said in Amiga and DosBox emulators not showing:
            That's because the interface is not installed. Whole Retropie is fitted on one, tiny old-school NES cartridge. It's abilities are limited, but it's supposed to run Amiga fine, if it can pull off arcades.
            RPi 4 4GB
            Retropie v 4.7.1
              edmaul69 @gordonfreemanjr
              This post is deleted!
              • I
                incunabula
                Check /etc/emulationstation/es_systems.cfg and see if there are entries for amiga and pc. This file needs entries for both if they are to appear in emulation station.
                  gordonfreemanjr @incunabula
                  Apparently I dont have such file in this folder. What do I do?
                  RPi 4 4GB
                  Retropie v 4.7.1
                  • I
                    incunabula
                    That's not the right folder. Check the path I typed above.
                      OMG, you're right. Thank you! I have been looking elsewhere for the whole time. The Amiga and PC entries are not there. What lines and where should I put it and can I do it from the File Manager?
                      RPi 4 4GB
                      Retropie v 4.7.1
                      • I
                        incunabula
                        This page should get you most of the way there: https://retropie.org.uk/docs/Add-a-New-System-in-EmulationStation/
                        I don't have any experience with 'File Manager' but you can certainly use nano to edit that file. I personally prefer to SSH into the Pi with PuTTY and edit with Notepad++, but that would require network connectivity in your case.
                          dmmarti
                          If the systems aren't in the es_systems.cfg file ..... it sounds like the emulators are not already installed.
                          You're gonna have to install them from the RetroPie setup > Manage Packages screen. By doing that, the systems will be auto-entered into the es_systems.cfg file.
                          Just manually adding the systems in .... still won't work if the emulators themselves are not already installed.
                          G 2 Replies Last reply Reply Quote 0
                            gordonfreemanjr @dmmarti
                            @dmmarti said in Amiga and DosBox emulators not showing:
                            Appears you're right. I have modified the .cfg file according to the instructions - I have copied the file onto a flashdrive, added the amiga lines on my pc and replaced the original, though I still have the previous version - and still no Amiga emulator visible. I'll try managing packages. Do I need the Internet connection for that?
                            RPi 4 4GB
                            Retropie v 4.7.1
                              As I supposed, I'm not able to install the packages. The option: "Install from source" takes me to the terminal, then the installation process is attempted and failed. It's the same for all packages: amiga, dosbox, scumm. "Could not install packages; ...".
                              RPi 4 4GB
                              Retropie v 4.7.1
                              • herb_fargusH
                                herb_fargus administrators @gordonfreemanjr
                                @gordonfreemanjr you need to be connected to the internet
                                  gordonfreemanjr @herb_fargus
                                  @herb_fargus said in Amiga and DosBox emulators not showing:
                                  Damn. How do I connect this little guy (check the pic out) to the Internet with no web interface installed?
                                  RPi 4 4GB
                                  Retropie v 4.7.1
                                    Tesla6
                                    No ethernet connection to the outside?
                                    Then you could open the module and connect an ethernet cable or use WiFi.
                                      gordonfreemanjr @Tesla6
                                      @tesla6 OK guys, I have managed to connect the thing to the Internet via an USB adapter. I have also installed all missing emulators. And... still nothing. :) I have:
                                      • the emulators installed,
                                      • the kickstart roms in the bios folder,
                                      • few .adf's in the roms/amiga directory,
                                      • the amiga lines in the .cfg file.
                                        What else do I need to do?
                                      2_1503570312714_IMG_5226.JPG 1_1503570312714_IMG_5225.JPG 0_1503570312706_IMG_5224.JPG
                                      RPi 4 4GB
                                      Retropie v 4.7.1
                                      maxbeanzM 1 Reply Last reply Reply Quote 0
                                      • space cadetS
                                        space cadet
                                        I'd just start over from scratch. Easy peasy
                                        • maxbeanzM
                                          maxbeanz @gordonfreemanjr
                                          @gordonfreemanjr Your kickstart roms need to be named kick13.rom, kick20.rom , kick31.rom
                                            gordonfreemanjr @maxbeanz
                                            @maxbeanz said in Amiga and DosBox emulators not showing:
                                            Holy shit. Testing ASAP.
                                            RPi 4 4GB
                                            Retropie v 4.7.1
