    Will GZDoom Ever Come To Retropie????
    doom
    95 Posts 6 Posters 33.4k Views
      RetroFreak89 @Brigane
      @brigane ok ill see if i can get trailblazer to run...
      Im wondering since u got trailblazer to run do you think you can get Russian Overkill to run as wel?
      Also what resolution you play at?
      BriganeB 1 Reply Last reply Reply Quote 0
      • BriganeB
        Brigane @RetroFreak89
        @retrofreak89
        I'm using default video mode since I'm mostly just testing the iwads at the moment.
        Also I got Russian Overkill working, it seems to run flawlessly when playing through the first map.
        Systems: Raspberry Pi 0/2/3 Model B+
        Os: RetroPie 4.5
        Frontend: Emulationstation & Attract Mode
          @brigane omg really?? How? The same way as blazer? I'm gomtry right now I got some time..
          Also where did u download it the one I found says gzdoom dev requires
            RetroFreak89
            I Just tried again with the above steps still crashes apon load :/
              RetroFreak89 @edmaul69
              @edmaul69
              Yo ed will you try something for me?
              This guy or woman below posted about that he or she got trailblazer and russian overkill mods running..those are the 2 that i cant get to run it also says recommanded for gzdoom but no matter what i do i followed up the steps like 5x it just keeps crashing..
              So im wondering if you can get it to work?
              Im curious i also want to play these since Its like one of the best mods
                edmaul69 @RetroFreak89
                @retrofreak89 i will try in a little bit when i get a chance.
                • BriganeB
                  @retrofreak89
                  I'm not quite sure where I got the mods from. When was the last time you updated zdoom? That might have something to do with it.
                  Just keep in mind that this probably won't run very smooth with zdoom. There might be some moments where the graphic seems messed up. That's why gzdoom is recommended.
                  Os: RetroPie 4.5
                  R edmaul69E 2 Replies Last reply Reply Quote 0
                    ayeshagurgaon
                    go to the part when you initially reach outside then Just somewhat ahead you will confront these cluster of creatures and a couple extensive ones outside on this upper stage it will slack like there's no tomorrow.??
                    http://www.gurgaonfairy.com/
                    On the off chance that you can simply play the main entire level and let me know how it went.
                      @brigane my zdoom is up to date matter infact i did a update 2 days ago.. i cant get it run ;( Sux in rly wanna play this mod
                        @edmaul69 alright thx i just cant get it working but apparently it does work
                        edmaul69E 3 Replies Last reply Reply Quote 0
                          @retrofreak89 when you are setting up the emulators.cfg make sure you are putting the caps and lowercase correctly in the names, including on the .wad and .pk3 file extensions?
                            @retrofreak89 trailblazer 1.4b doesnt work. I assume he is using an older version which i cannot find any other downloads anywhere.
                              edmaul69 @Brigane
                              @brigane can you go into my profile and click on my email address and send the file to me? Then i can test and send to retrofreak. I think you have an older version which is why it works for you.
                              • BriganeB
                                Brigane @edmaul69
                                @edmaul69
                                You're absolutely right. The version I'm using is v. 1.2d. I've emailed you a place to grab it.
                                Os: RetroPie 4.5
                                edmaul69E R 3 Replies Last reply Reply Quote 0
                                  edmaul69 @Brigane
                                  @brigane awesome. Thank you.
                                    @retrofreak89 file sent. Check your email. If not look in your junk folder.
                                      edmaul69 @Brigane
                                      @brigane i have an issue with trailblazer. When i pick up ammo it doesnt reload my gun. I ran out of ammo right away and had to use my knife. Plus the secrets that were supposed to be revealed didnt open up. Do you have the same issues?
                                        @edmaul69 thanks bro any issues with this version also he said he got guncaster,russian overkill working too but those dont work either i think he using older version then?
                                          @brigane Nice what about the other mods you got working like russian overkill, guncaster etc.. what version are those? The newest one dont work for me
                                            @edmaul69 also how do I know which mods work and which one doesn't? Without trying it because trailblazer doesn't work but the older one does how did u find that out?
