    Pi Zero W GBA [BUILD]
    pi zero wgbascreenbuildwip
    84 Posts 5 Posters 36.5k Views
      TechieAndroid @AluLagoa
      @alulagoa
      That is not my screen and that link doesn't have the information I needed. I figured it out on my own though.
        TechieAndroid @moosepr
        @moosepr
        Thanks I looked at that and noticed a few pins I've overlooked, I'll make sure to connect everything up to the appropriate pins.
        I'm going to connect the 2 VDD 3.3v on the screen to my PowerBoost 1000 since I didn't want to draw that from the GPIO itself, plus I've already been powering the Pi from the GPIO. I'll GND to the PowerBoost too. I'm going to just connect both 3.3v VDD wires from the screen to the 3.3v on the PowerBoost same goes for connecting both GND wires to the GND on the PowerBoost.
        In the end the Pi and display are separated drawing different voltages from the PowerBoost. And the other wires from the display (the data connections) will be connected to the GPIO on the Pi.
        It should work. Let me know what you think.
        Oh and yes it is a ili9341 screen.
          TechieAndroid
          @moosepr
          Some quick clarification. I took another look at your post and was curious what D/C stood for because I don't have that on mine. The other I was able to match up.
          BL is BL on mine
          SCK is CLK on mine
          MISO is MISO on mine
          MOSI is MOSI on mine
          CS is CS on mine
          RST is RST on mine
          D/C is ? on mine (it's going to a GPIO pin I see)
          VIN is VDD on mine (I have two of these, both 3.3v)
          GND is GND on mine (I have two of these too)
          Also I thought about the inconveniences of connecting part of the display to the PowerBoost and decided not to. I see you have your power and ground going to the GPIO pins.
            TechieAndroid
            Dang it. Why isn't it working?! The screen is black when the pi gets power. Maybe if I knew what D/C was on the other screen I could connect that on mine. Not sure if that is why it's not turning on though...
              TechieAndroid
              mooseprM 1 Reply Last reply Reply Quote 0
              • mooseprM
                moosepr @TechieAndroid
                @techieandroid at a guess i would say your d/c is the rs on the botton of the connector. There may be some investigation needed on the board to see if the MISO and MOSI pins are there for the touch controller, or for the screen, or both. You may need to lift the screen from the pcb and follow some trances to fully see what is going on
                want to get a tft into your project, look no further than here https://retropie.org.uk/forum/topic/7464/ili9341-tft-screen-guide
                  @moosepr
                  Thanksv I'll do that. I saw that the GND and GND pins we're already connected with a trace on the board, same goes for VDD. So I guess I only needed to connect to one point, but it doesn't matter.
                    TechieAndroid
                    I ripped the dang ribbon cable connection under the LCD (it was literally impossible to see where it was under there, I had a light and it still didn't help). I admit my strong suit isn't finding out which LCD wires are for what (they aren't marked if you assumed they were, hence why I'm having problems), I have no previous experience in this specific field. I need help. I don't know what I can really do atm. My multimeter bit the dust a while back and I haven't been able to get another. I wish I had an oscilloscope. But I don't. :/ Guess I'll just give up on this screen. Dang it. I hate myself for listening to someone online telling me I could use a ili9341 screen when this screen has no previous history with Pis on the internet.
                      TechieAndroid
                      I'm just glad it didn't mess anything up in the process. So my Pi, PowerBoost and battery still work.
                        AluLagoa
                        This is the ili9341 me and @moosepr used:
                        You used the other version.
                        The one we used works decently enough for a cheap handheld.
                          TechieAndroid
                          That screen is nothing like mine.
                          • mooseprM
                            @techieandroid sorry to hear you ave had problems. It would appear not all ili9341 screens are created equal. Tracing the path from the screen ribbon to the pins is leaning towards the advanced side of things. I have just had a look on aliexpress, and all the 3.5 inch screens that come up when searching for ili9341 are actually 320x480 resolution, and so are probably not really ili9341 screens!!
                            try and get your hands on a screen that only has a single row of connectors (like on the red boards you will see) and if doubt, send us a link to the screen you are thinking of buying, and we can see if its good to go before you buy
                              TechieAndroid
                              @moosepr
                              Okay. Yeah I'm going to get one of those other screens I guess. Who would have it for the cheapest price and be located in north america?
                                TechieAndroid
                                http://www.ebay.com/itm/240x320-SPI-TFT-2-8-LCD-Serial-Port-Module-PCB-Adapter-Micro-SD-ILI9341-5V-3-3-/172822523658?hash=item283d066f0a:g:vLUAAOSwJehZk93F
                                Is this one good?
                                A mooseprM 2 Replies Last reply Reply Quote 0
                                  AluLagoa @TechieAndroid
                                  @techieandroid
                                  That one looks good to me.
                                  • mooseprM
                                    @techieandroid yeah thats the baby!!
                                      @alulagoa said in Pi Zero W GBA [BUILD]:
                                      @techieandroid
                                      @moosepr said in Pi Zero W GBA [BUILD]:
                                      Okay thanks guys I got it.
                                      Should come soon. Then I can finish building it. :)
                                      I've got my live stream setup so I'll stream it live when I begin building it.
                                      FWIF I think some will watch.
                                        TechieAndroid
                                        @moosepr
                                        Okay so I've got and setup the new screen but I don't like it at all. I don't know if this can be tweaked (probably, I just haven't tried yet) but the screen's dpi is messed up (everything it too small, which is probably just a wrongly set resolution from before when I had a tv connected), and the other major problem is it stutters so bad I can't play any game on it (it stutters, drops frames and tears).
                                        • spruce_m00seS
                                          spruce_m00se @Hex
                                          @hex I would disagree with this, I have one from Ebay which I converted to 5v and I think its junk, the contrast is poor, and when you have white pixels on a black background you get ghosting across that whole horizintal line of pixels, not the mention that the screen gets incredibly hot.
                                          it is also poor resolution,
                                          yes it works for gaming, just about, but if you are going to invest a good amount of time then I would try to get a better screen.
                                          • HexH
                                            Hex
                                            @spruce_m00se Can you show a comparison photo/video?
                                            spruce_m00seS 1 Reply Last reply Reply Quote 0
