    Pi Zero W GBA [BUILD]
    pi zero wgbascreenbuildwip
    84 Posts 5 Posters 36.4k Views
    • mooseprM
      moosepr @TechieAndroid
      @techieandroid your best bet with the 3.2" screen, is to find a datasheet for it. There are normally some pins on the screen that allow you alter the configuration. Sometimes its just a case of connecting a pin to gnd or vcc to put it in spi mode
      want to get a tft into your project, look no further than here https://retropie.org.uk/forum/topic/7464/ili9341-tft-screen-guide
        TechieAndroid @moosepr
        @moosepr
        I suppose so, I'll look for one.
        What do you think of this screen?
        It's advertised as plug and play, do you think the Pi would have a compatible driver for it to work instantly like that?
        mooseprM 1 Reply Last reply Reply Quote 0
        • mooseprM
          @techieandroid the listing says that screen is ILI9341 so it should just be a quick swap with the one you already have :)
            TechieAndroid
            Okay I've almost finished my long dead project but I'm having trouble wiring in the GBA's controller board into the Pi in a way that it recognizes it as a configurable controller. Can I do this or am I trying to do something that's simply not possible?
