    Wireless controller with Raspberry Pi 3
    nescontroller
    3 Posts 2 Posters 2.1k Views
    • N
      nickmeister
      Hi, new to the forum and wondered if there is a list of wireless controllers that will work with Raspberry Pi 3 w Retropie? I believe I have Bluetooth built in so if any controllers will work without a dongle?
      Many thanks
        mitu Global Moderator @nickmeister
        @nickmeister The Controller section in the Wiki has a list of controllers and how they work with RetroPie, if you have a controller in mind you can check there.
        I had good experience with the PS4 DualShock controllers and the 8Bitdo SFC30 one, both worked without problems with the RPI 3 bluetooth.
        • N
          nickmeister @mitu
          @mitu thanks very much will check those out
