    (SOLVED) update problem and kodi wont start anymore
    updatekodi crashscreen stretch
    7 Posts 3 Posters 5.2k Views
      darthlink
      Hello everyone, i have actually more then one problem that i would need help with please.
      • not sure that my PI actually does updates anymore?
      • Kodi wont start anymore ( i have the log file )
      • screen is too large for the tv somehow
      First, for the updates, i dont think it does any updates anymore because it seem to be ignoring things but i may be wrong, maybe you can tell me with this:
      Hit http://mirrordirector.raspbian.org jessie InRelease
      Hit http://archive.raspberrypi.org jessie InRelease
      Hit http://archive.raspberrypi.org jessie/main armhf Packages
      Hit http://archive.raspberrypi.org jessie/ui armhf Packages
      Hit http://mirrordirector.raspbian.org jessie/main armhf Packages
      Hit http://mirrordirector.raspbian.org jessie/contrib armhf Packages
      Hit http://mirrordirector.raspbian.org jessie/non-free armhf Packages
      Hit http://mirrordirector.raspbian.org jessie/rpi armhf Packages
      Ign http://archive.raspberrypi.org jessie/main Translation-en_GB
      Ign http://mirrordirector.raspbian.org jessie/contrib Translation-en_GB
      Ign http://archive.raspberrypi.org jessie/ui Translation-en_GB
      Ign http://mirrordirector.raspbian.org jessie/main Translation-en_GB
      Ign http://mirrordirector.raspbian.org jessie/non-free Translation-en_GB
      Ign http://mirrordirector.raspbian.org jessie/rpi Translation-en_GB
      Reading package lists...
      does the ign means that it ignoring things ?
      There is my log file from kodi:
       ############## Kodi CRASH LOG ###############
      ################ SYSTEM INFO ################
       Date: Sun 17 Sep 22:00:46 EDT 2017
       Kodi Options:
       Arch: armv7l
       Kernel: Linux 4.9.35-v7+ #1014 SMP Fri Jun 30 14:47:43 BST 2017
       Release: Raspbian GNU/Linux 8 (jessie)
      ############## END SYSTEM INFO ##############
      ############### STACK TRACE #################
      =====>  Core file: /home/pi/core (2017-09-17 22:00:46.161264194 -0400)
      [New LWP 16812]
      [New LWP 16813]
      [New LWP 16814]
      [New LWP 16819]
      [New LWP 16821]
      [New LWP 16823]
      [New LWP 16817]
      [New LWP 16822]
      [New LWP 16818]
      [New LWP 16825]
      [New LWP 16827]
      [New LWP 16824]
      [New LWP 16820]
      [New LWP 16826]
      [Thread debugging using libthread_db enabled]
      Using host libthread_db library "/lib/arm-linux-gnueabihf/libthread_db.so.1".
      Core was generated by `/usr/lib/arm-linux-gnueabihf/kodi/kodi_v7.bin --lircdev /var/run/lirc/lircd'.
      Program terminated with signal SIGILL, Illegal instruction.
      #0  0x756d2758 in main_arena () from /lib/arm-linux-gnueabihf/libc.so.6
      Thread 14 (Thread 0x6dbfe3b0 (LWP 16826)):
      #0  0x76e9c7a4 in __pthread_cond_wait (cond=0x1ff73d8 <g_OMXImage+496>, mutex=0x1ff73bc <g_OMXImage+468>) at pthread_cond_wait.c:187
      #1  0x0059cd3c in COMXImage::Process() ()
      #2  0x00859b10 in CThread::Action() ()
      #3  0x00859dac in CThread::staticThread(void*) ()
      #4  0x76e97e90 in start_thread (arg=0x6dbfe3b0) at pthread_create.c:311
      #5  0x75666598 in ?? () at ../ports/sysdeps/unix/sysv/linux/arm/nptl/../clone.S:92 from /lib/arm-linux-gnueabihf/libc.so.6
      Backtrace stopped: previous frame identical to this frame (corrupt stack?)
      Thread 13 (Thread 0x717ff3b0 (LWP 16820)):
      #0  0x7565ef2c in ioctl () at ../sysdeps/unix/syscall-template.S:81
      #1  0x75b9d010 in completion_thread () from /opt/vc/lib/libvchiq_arm.so
      #2  0x75b83cc4 in vcos_thread_entry (arg=0x75bb0318 <vchiq_instance+16>) at /home/dc4/projects/staging/userland/interface/vcos/pthreads/vcos_pthreads.c:144
      #3  0x76e97e90 in start_thread (arg=0x717ff3b0) at pthread_create.c:311
      #4  0x75666598 in ?? () at ../ports/sysdeps/unix/sysv/linux/arm/nptl/../clone.S:92 from /lib/arm-linux-gnueabihf/libc.so.6
      Thread 12 (Thread 0x6f7ff3b0 (LWP 16824)):
      #0  0x76e9c7a4 in __pthread_cond_wait (cond=cond@entry=0x718025d8, mutex=mutex@entry=0x718025bc) at pthread_cond_wait.c:187
      #1  0x75b83da8 in _timer_thread (arg=0x718025b8) at /home/dc4/projects/staging/userland/interface/vcos/pthreads/vcos_pthreads.c:722
      #2  0x76e97e90 in start_thread (arg=0x6f7ff3b0) at pthread_create.c:311
      #3  0x75666598 in ?? () at ../ports/sysdeps/unix/sysv/linux/arm/nptl/../clone.S:92 from /lib/arm-linux-gnueabihf/libc.so.6
      Thread 11 (Thread 0x6d3fe3b0 (LWP 16827)):
      #0  0x76e9cb30 in __pthread_cond_timedwait (cond=0x6d3fdc70, mutex=0x6d3fdca8, abstime=0x6d3fdbc0) at pthread_cond_timedwait.c:199
      #1  0x00857d98 in XbmcThreads::CEventGroup::wait(unsigned int) ()
      #2  0x0057e364 in CRemoteControl::Process() ()
      #3  0x00859b10 in CThread::Action() ()
      #4  0x00859dac in CThread::staticThread(void*) ()
      #5  0x76e97e90 in start_thread (arg=0x6d3fe3b0) at pthread_create.c:311
      #6  0x75666598 in ?? () at ../ports/sysdeps/unix/sysv/linux/arm/nptl/../clone.S:92 from /lib/arm-linux-gnueabihf/libc.so.6
      Thread 10 (Thread 0x6e3fe3b0 (LWP 16825)):
      #0  0x76e9ea40 in do_futex_wait (isem=isem@entry=0x7180276c) at ../nptl/sysdeps/unix/sysv/linux/sem_wait.c:48
      #1  0x76e9eaf4 in __new_sem_wait (sem=0x7180276c) at ../nptl/sysdeps/unix/sysv/linux/sem_wait.c:69
      #2  0x75b9fb60 in vchiu_queue_pop () from /opt/vc/lib/libvchiq_arm.so
      #3  0x72355d70 in ilcs_task () from /opt/vc/lib/libopenmaxil.so
      #4  0x75b83cc4 in vcos_thread_entry (arg=0x71802628) at /home/dc4/projects/staging/userland/interface/vcos/pthreads/vcos_pthreads.c:144
      #5  0x76e97e90 in start_thread (arg=0x6e3fe3b0) at pthread_create.c:311
      Thread 9 (Thread 0x72b683b0 (LWP 16818)):
      #0  0x76e9cb30 in __pthread_cond_timedwait (cond=0x3e6dc90, mutex=0x3e6dcc8, abstime=0x72b67d28) at pthread_cond_timedwait.c:199
      #1  0x010daf50 in ActiveAE::CActiveAE::Process() ()
      #4  0x76e97e90 in start_thread (arg=0x72b683b0, arg@entry=<error reading variable: Cannot access memory at address 0x4f8>) at pthread_create.c:311
      /home/pi/dev/gdb-7.7.1+dfsg/gdb/frame.c:472: internal-error: get_frame_id: Assertion `fi->this_id.p' failed.
      A problem internal to GDB has been detected,
      further debugging may prove unreliable.
      Quit this debugging session? (y or n) [answered Y; input not from terminal]
      Create a core file of GDB? (y or n) [answered Y; input not from terminal]
      ############# END STACK TRACE ###############
      ################# LOG FILE ##################
      22:00:43.519 T:1945383584  NOTICE: special://profile/ is mapped to: special://masterprofile/
      22:00:43.519 T:1945383584  NOTICE: -----------------------------------------------------------------------
      22:00:43.519 T:1945383584  NOTICE: Starting Kodi (17.3 Git:20170525-1789806-dirty). Platform: Linux ARM 32-bit
      22:00:43.519 T:1945383584  NOTICE: Using Release Kodi x32 build (version for Raspberry Pi)
      22:00:43.519 T:1945383584  NOTICE: Kodi compiled May 25 2017 by GCC 4.9.2 for Linux ARM 32-bit version 3.16.7 (200711)
      22:00:43.520 T:1945383584  NOTICE: Running on Raspbian GNU/Linux 8 (jessie), kernel: Linux ARM 32-bit version 4.9.35-v7+
      22:00:43.568 T:1945383584  NOTICE: FFmpeg version/source: ffmpeg-3.1-kodi
      22:00:43.569 T:1945383584  NOTICE: Host CPU: ARMv7 Processor rev 4 (v7l), 4 cores available
      22:00:43.569 T:1945383584  NOTICE: ARM Features: Neon enabled
      22:00:43.569 T:1945383584  NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
      22:00:43.569 T:1945383584  NOTICE: special://xbmcbin/ is mapped to: /usr/lib/arm-linux-gnueabihf/kodi
      22:00:43.569 T:1945383584  NOTICE: special://xbmcbinaddons/ is mapped to: /usr/lib/arm-linux-gnueabihf/kodi/addons
      22:00:43.569 T:1945383584  NOTICE: special://masterprofile/ is mapped to: /home/pi/.kodi/userdata
      22:00:43.569 T:1945383584  NOTICE: special://envhome/ is mapped to: /home/pi
      22:00:43.569 T:1945383584  NOTICE: special://home/ is mapped to: /home/pi/.kodi
      22:00:43.569 T:1945383584  NOTICE: special://temp/ is mapped to: /home/pi/.kodi/temp
      22:00:43.569 T:1945383584  NOTICE: special://logpath/ is mapped to: /home/pi/.kodi/temp
      22:00:43.569 T:1945383584  NOTICE: The executable running is: /usr/lib/arm-linux-gnueabihf/kodi/kodi_v7.bin
      22:00:43.569 T:1945383584  NOTICE: Local hostname: raspberrypi
      22:00:43.569 T:1945383584  NOTICE: Log File is located: /home/pi/.kodi/temp//kodi.log
      22:00:43.569 T:1945383584  NOTICE: -----------------------------------------------------------------------
      22:00:44.092 T:1945383584   ERROR: DBus: Error org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files
      22:00:44.190 T:1945383584  NOTICE: load settings...
      22:00:44.476 T:1945383584  NOTICE: Found 2 Lists of Devices
      22:00:44.476 T:1945383584  NOTICE: Enumerated PI devices:
      22:00:44.476 T:1945383584  NOTICE:     Device 1
      22:00:44.476 T:1945383584  NOTICE:         m_deviceName      : HDMI
      22:00:44.476 T:1945383584  NOTICE:         m_displayName     : HDMI
      22:00:44.476 T:1945383584  NOTICE:         m_displayNameExtra:
      22:00:44.476 T:1945383584  NOTICE:         m_deviceType      : AE_DEVTYPE_HDMI
      22:00:44.476 T:1945383584  NOTICE:         m_channels        : FL,FR
      22:00:44.476 T:1945383584  NOTICE:         m_sampleRates     : 8000,11025,16000,22050,24000,32000,44100,48000,88200,96000,176400,192000
      22:00:44.476 T:1945383584  NOTICE:         m_dataFormats     : AE_FMT_FLOAT,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP,AE_FMT_RAW
      22:00:44.476 T:1945383584  NOTICE:         m_streamTypes     : STREAM_TYPE_AC3,STREAM_TYPE_EAC3,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_512
      22:00:44.476 T:1945383584  NOTICE:     Device 2
      22:00:44.476 T:1945383584  NOTICE:         m_deviceName      : Analogue
      22:00:44.476 T:1945383584  NOTICE:         m_displayName     : Analogue
      22:00:44.477 T:1945383584  NOTICE:         m_deviceType      : AE_DEVTYPE_PCM
      22:00:44.477 T:1945383584  NOTICE:         m_channels        : FL,FR
      22:00:44.477 T:1945383584  NOTICE:         m_sampleRates     : 48000
      22:00:44.477 T:1945383584  NOTICE:         m_dataFormats     : AE_FMT_FLOAT,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP
      22:00:44.477 T:1945383584  NOTICE:         m_streamTypes     : No passthrough capabilities
      22:00:44.477 T:1945383584  NOTICE:     Device 3
      22:00:44.477 T:1945383584  NOTICE:         m_deviceName      : Both
      22:00:44.477 T:1945383584  NOTICE:         m_displayName     : HDMI and Analogue
      22:00:44.477 T:1945383584  NOTICE:         m_displayNameExtra:
      22:00:44.477 T:1945383584  NOTICE: Enumerated ALSA devices:
      22:00:44.477 T:1945383584  NOTICE:     Device 1
      22:00:44.477 T:1945383584  NOTICE:         m_deviceName      : default
      22:00:44.477 T:1945383584  NOTICE:         m_displayName     : Playback/recording through the PulseAudio sound server
      22:00:44.477 T:1945383584  NOTICE:         m_channels        : FL,FR,BL,BR,FC,LFE,SL,SR,UNKNOWN1,UNKNOWN2,UNKNOWN3,UNKNOWN4,UNKNOWN5,UNKNOWN6,UNKNOWN7,UNKNOWN8
      22:00:44.477 T:1945383584  NOTICE:         m_sampleRates     : 5512,8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000
      22:00:44.477 T:1945383584  NOTICE:         m_dataFormats     : AE_FMT_FLOAT,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE,AE_FMT_U8
      22:00:44.477 T:1945383584  NOTICE:     Device 2
      22:00:44.477 T:1945383584  NOTICE:         m_deviceName      : pulse
      22:00:44.477 T:1945383584  NOTICE:         m_displayName     : PulseAudio Sound Server
      22:00:44.478 T:1945383584  NOTICE:         m_sampleRates     : 5512,8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000
      22:00:44.478 T:1945383584  NOTICE:         m_dataFormats     : AE_FMT_FLOAT,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE,AE_FMT_U8
      22:00:44.478 T:1945383584  NOTICE:         m_streamTypes     : No passthrough capabilities
      22:00:44.478 T:1945383584  NOTICE:     Device 3
      22:00:44.478 T:1945383584  NOTICE:         m_deviceName      : @:CARD=vc4hdmi,DEV=0
      22:00:44.478 T:1945383584  NOTICE:         m_displayName     : vc4-hdmi
      22:00:44.478 T:1945383584  NOTICE:         m_displayNameExtra: Analog
      22:00:44.478 T:1945383584  NOTICE:         m_deviceType      : AE_DEVTYPE_PCM
      22:00:44.478 T:1945383584  NOTICE:         m_channels        : FL,FR
      22:00:44.478 T:1945383584  NOTICE:         m_sampleRates     : 32000,44100,48000
      22:00:44.478 T:1945383584  NOTICE:     Device 4
      22:00:44.478 T:1945383584  NOTICE:         m_deviceName      : iec958:CARD=vc4hdmi,DEV=0
      22:00:44.478 T:1945383584  NOTICE:         m_displayNameExtra: S/PDIF
      22:00:44.478 T:1945383584  NOTICE:         m_deviceType      : AE_DEVTYPE_IEC958
      22:00:44.478 T:1945383584  NOTICE:         m_dataFormats     : AE_FMT_RAW,AE_FMT_S24NE3,AE_FMT_S24NE4,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE,AE_FMT_U8
      22:00:44.478 T:1945383584  NOTICE:         m_streamTypes     : STREAM_TYPE_AC3,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_512
      22:00:44.738 T:1945383584  NOTICE: Loaded settings file from special://xbmc/system/advancedsettings.xml
      22:00:44.738 T:1945383584  NOTICE: Contents of special://xbmc/system/advancedsettings.xml are...
                                                  <?xml version="1.0" encoding="UTF-8" ?>
                                                  <advancedsettings>
                                                    <fanartres>720</fanartres>
                                                    <imageres>540</imageres>
                                                    <video>
                                                      <busydialogdelayms>750</busydialogdelayms>
                                                    </video>
                                                    <samba>
                                                      <clienttimeout>30</clienttimeout>
                                                    </samba>
                                                    <cache>
                                                      <memorysize>31457280</memorysize>
                                                    </cache>
                                                  </advancedsettings>
      22:00:44.741 T:1945383584  NOTICE: Loaded settings file from special://profile/advancedsettings.xml
      22:00:44.741 T:1945383584  NOTICE: Contents of special://profile/advancedsettings.xml are...
                                                  <advancedsettings>
                                                    <cache>
                                                      <buffermode>1</buffermode>
                                                      <memorysize>139460608</memorysize>
                                                      <readfactor>20</readfactor>
                                                    </cache>
                                                  </advancedsettings>
      22:00:44.742 T:1945383584  NOTICE: Default Video Player: VideoPlayer
      22:00:44.742 T:1945383584  NOTICE: Default Audio Player: paplayer
      22:00:44.742 T:1945383584  NOTICE: Disabled debug logging due to GUI setting. Level 0.
      22:00:44.742 T:1945383584  NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
      22:00:44.743 T:1945383584  NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
      22:00:44.744 T:1945383584  NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
      22:00:44.745 T:1945383584  NOTICE: Loaded playercorefactory configuration
      22:00:44.745 T:1945383584  NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
      22:00:44.746 T:1945383584  NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
      22:00:44.859 T:1945383584  NOTICE: Running database version Addons27
      22:00:45.693 T:1945383584  NOTICE: ADDONS: Using repository repository.xbmc.org
      22:00:45.693 T:1945383584  NOTICE: ADDONS: Using repository repository.exodus
      22:00:45.693 T:1945383584  NOTICE: ADDONS: Using repository repository.smash
      22:00:45.693 T:1945383584  NOTICE: ADDONS: Using repository repository.colossus
      22:00:46.006 T:1945383584  NOTICE: Raspberry PI firmware version: Jul  3 2017 14:16:43
                                                  Copyright (c) 2012 Broadcom
                                                  version 4139c62f14cafdb7d918a3eaa0dbd68cf434e0d8 (tainted) (release)
      22:00:46.007 T:1945383584  NOTICE: ARM mem: 944MB GPU mem: 64MB MPG2:0 WVC1:0
      22:00:46.007 T:1945383584  NOTICE: cache.memorysize: 133MB libass.cache: 0MB
      22:00:46.008 T:1945383584  NOTICE: Config:
                                                  arm_freq=1200
                                                  audio_pwm_mode=1
                                                  config_hdmi_boost=5
                                                  core_freq=400
                                                  desired_osc_freq=0x36ee80
                                                  disable_commandline_tags=2
                                                  disable_l2cache=1
                                                  force_eeprom_read=1
                                                  force_pwm_open=1
                                                  framebuffer_ignore_alpha=1
                                                  framebuffer_swap=1
                                                  gpu_freq=300
                                                  hdmi_channel_map=8
                                                  hdmi_force_cec_address=65535
                                                  init_uart_clock=0x2dc6c00
                                                  lcd_framerate=60
                                                  mask_gpu_interrupt0=1024
                                                  mask_gpu_interrupt1=26370
                                                  over_voltage_avs=0x1b774
                                                  over_voltage_avs_boost=0x1b774
                                                  overscan_bottom=48
                                                  overscan_left=48
                                                  overscan_right=48
                                                  overscan_top=48
                                                  pause_burst_frames=1
                                                  program_serial_random=1
                                                  sdram_freq=450
                                                  temp_limit=85
                                                  device_tree=-
      22:00:46.008 T:1945383584  NOTICE: InitWindowSystem: Using EGL Implementation: raspberrypi
      ############### END LOG FILE ################
      ############ END Kodi CRASH LOG #############
      And for the screen th at is displayed too large on the tv, it does not seem to be the tv overscan because the tv does not seem to have that setting.
      i tryed to change the setting in the /boot/config.txt file but that does not do anything at all. I change the overscan setting but nothing happen even after having rebooted.
      What can i do now for these issues please ?
        dankcushions Global Moderator
        @darthlink said in update problem and kodi wont start anymore:
        follow https://github.com/RetroPie/RetroPie-Setup/wiki/Overscan
        hopefully you can fix it via your tv, as per the link, but if you want to do it via the config you need to use overscan_scale = 1 otherwise none of those settings will have any effect.
        also please format all code blocks as per https://retropie.org.uk/forum/topic/3/read-this-first
          darthlink @dankcushions
          @dankcushions
          THX, my overscan setting was already uncomon but it was at =0 so i only changed it to =1 and now i can only wait to get home later and see if that solved or not the problem.
          I will let you know.
          thx.
            darthlink
            Good morning, so i have tryed this morning and the screen is still the same.
            • This is the same HDMI cable but into a diferent TV
            • The tv does not seem to have any overscan setting, only the regulars screen settings like: 4:9, 16:9, zoom, standard
            • in every tv setting, i loose about 2 inch ( proportionally ) up and left and top and bottom
            here is my config.txt file:
            # http://rpf.io/configtxtreadme
            #hdmi_safe=1
            disable_overscan=1
            #overscan_left=-20
            #overscan_right=-20
            #overscan_top=-18
            #overscan_bottom=-18
            # overscan.
            #framebuffer_width=1280
            #framebuffer_height=720
            #hdmi_force_hotplug=1
            #hdmi_group=1
            #hdmi_mode=1
            #hdmi_drive=2
            # no display
            #config_hdmi_boost=4
            # uncomment for composite PAL
            #sdtv_mode=2
            #arm_freq=800
            #dtparam=i2c_arm=on
            #dtparam=i2s=on
            #dtparam=spi=on
            # Uncomment this to enable the lirc-rpi module
            #dtoverlay=lirc-rpi
            dtparam=audio=on
            start_x=0
            #gpu_mem=256
            #gpu_mem_256=128
            #gpu_mem_512=256
            #gpu_mem_1024=256
            #overscan_scale=1
            dtoverlay=vc4-kms-v3d
            I had also forgot to say in the first message that my emulationstation does not start anymore kinda like with kodi. It keep saying :
            • failed to add service, already in use
            The only that that is working as of now is to start it , it does get into command prompt ( if i can say that ) and if i write startx that also work but again, i loose about 2 inch on every sides.
            RascasR 1 Reply Last reply Reply Quote 0
            • RascasR
              Rascas @darthlink
              This enables the open-source 3d OpenGL video driver, it won't work in RetroPie, disable it.
              #gpu_mem=256
              #gpu_mem_256=128
              #gpu_mem_512=256
              #gpu_mem_1024=256
              #overscan_scale=1
              This options are important also, enable (uncomment.) them.
              This should fix your problems.
                darthlink
                Thanks, i will try that and let you know if it solved the problem in the evening or tomorow.
                  darthlink
                  Thank you so much, everything is working fine now! The screen is finally back to normal and emulationstation is opening and so is kodi.
                  Thank you again, yall are great and needed help ;)
