    Best case to keep raspberry pie 3 cool?
    coolcaseoverheating
    40 Posts 13 Posters 15.5k Views
      Deltax5
      I have the cana kit and my raspberry pie seems to get the temperature meter after many hours of use, even with the heatsinks. I emailed them and they said it's normal and not to worry about it. Is this correct or is my board bad. Or do I need a better case with a fan or something? Which one is best? Nothin to laud.
        edmaul69 @Deltax5
        @deltax5 which case did you get with the canakit?
        • L
          linkreincarnate
          Plastic cases without fans aren't going to cool anything. Get a Biqu and sand off the paint on the heat pillar or spend a few extra bucks and get a Flirc
          Both use passive cooling so no fan noise and they work as well as active cooled cases.
            pjft @linkreincarnate
            @linkreincarnate how does this work? Does the whole case then get hot to the touch?
            I'm curious about getting one for an enclosed arcade cabinet environment, hence the question. Either that or use the fan.
            • DD-IndeedD
              DD-Indeed
              I examined those cases and indeed, they're really good cases if the Raspi is going to be lightly stressed. But, if you are stressing it really heavily, I think that those cases will face the problem of thermal runaway, where the cooling capabilities of the case is not enough to keep up with the heat dissipation.
              My soul rests, when I hear the PS1 boot music
                RetroFreak89
                Best bet is a flirc case or a cheapy plastic case with a fan
                • RiverstormR
                  Riverstorm
                  It seems like the biggest danger I've seen at this point when it comes to heat is throttling vs. actually damaging the Pi which effects your gaming session. :)
                  I've had good luck with this case. While it's not my personal favorite for aesthetics I've grown fond of it. It comes with low profile aluminum heatsinks, fan and does a pretty decent job. The ports are easily accessible. The negative space also helps in cooling. Not a bad case for under $10 and they are stackable if needed.
                  If you Google Pi 3 cases with fans they are a dime a dozen with a multitude of designs and colors. The fans definitely make a difference in dissipating heat. If it's in a cab or some enclosure you might want to think about venting somewhere above the Pi or some other combination of active/passive cooling.
                    Deltax5
                    I wonder if i just take off the thermal pad from the kana kit heatsink and cut out a thermal pad that's better quality would i get the same resalts. So far im looking at these cases.
                    this one it's open and afraid of dust.
                    https://www.amazon.ca/Excellent-Cooling-System-Heatsink-Raspberry/dp/B072ZZ423F/ref=sr_1_41?s=pc&ie=UTF8&qid=1505945213&sr=1-41&keywords=raspberry+pi+case
                    This one blows the hot air out.
                    https://www.amazon.ca/Eleduino-Raspberry-Case-Aluminum-Blue/dp/B071YPZFZ4/ref=sr_1_32?s=pc&ie=UTF8&qid=1505945213&sr=1-32&keywords=raspberry+pi+case
                    https://www.amazon.ca/Double-Cool-Raspberry-Case-Heatsink/dp/B072ZY3X2Q/ref=sr_1_21?s=pc&ie=UTF8&qid=1505944893&sr=1-21&keywords=raspberry+pi+case
                    This one looks cool but one bad review saying the fan died.
                    https://www.amazon.ca/Enokay-Case-Raspberry-Model-Quality/dp/B011RBK2MG/ref=sr_1_26?s=pc&ie=UTF8&qid=1505945153&sr=1-26&keywords=raspberry+pi+case
                    The case you guys are raving about. maybe get this one with a thermal pad thats better.
                    https://www.amazon.ca/Flirc-Raspberry-Case-Gen2-Model/dp/B07349HT26/ref=sr_1_2?s=pc&ie=UTF8&qid=1505945482&sr=1-2
                    This one riverstorm said cost so much more then it costs in the us for some reason and also afrade of dust.
                    https://www.amazon.ca/iUniker-Transparent-External-Dissipating-Raspberry/dp/B01LXSMY1N/ref=sr_1_1?s=electronics&ie=UTF8&qid=1505946127&sr=1-1&keywords=raspberry+pi+case+iUniker
                    DD-IndeedD 1 Reply Last reply Reply Quote 0
                    • DD-IndeedD
                      DD-Indeed @Deltax5
                      @deltax5
                      Pretty much all of those fully closed cases are useless with fans, as the air can't get out from them. Those cases with the top lid but open sides are propably the best cases available, but of course, not so safe or good looking. And when talking about the fan, the fan always should be attached to the cooler in order to get proper air pressure going through the cooler.
                        Deltax5
                        Should I even worry about dust or anything hitting the board when it's on for the open one's. It will be in a safe place so I don't think anything will hit the board. Is the one in the first link as good it's cheeper then the iUniker.
                        The Flirc one is tempting thou.
                        • RiverstormR
                          Riverstorm @Deltax5
                          @deltax5 said in Best case to keep raspberry pie 3 cool?:
                          I haven't had many issues with dust. I do move mine around occasionally and maybe that's enough to knock things loose and keep any significant dust buildup from happening.
                          I've had good luck with the 40MM fan attached to the housing and a low profile heatsink to the die with a gap between. Traditionally in PC land it's more effective to have it attached to the heatsink but in this scenario it works and moves enough air to make a noticeable difference in cooling.
                          I do have a smaller 15MM fan that is directly attached to the heatsink and then directly to the die via thermal tape but I find the larger fan and open case do a better job at keeping it cooler and that might simply be because the fan is 25MM larger on the open case.
                          • caver01C
                            caver01
                            I was just thinking that you could use this as a case to keep your Raspberri Pi cool:
                            RiverstormR 1 Reply Last reply Reply Quote 5
                            • RiverstormR
                              Riverstorm @caver01
                              @caver01 said in Best case to keep raspberry pie 3 cool?:
                              That's classic! If that can't keeps things cool nothing can! :) We were just having a conversation this morning about the old tin lunchboxes vs. the newer soft side ones.
                                Deltax5
                                So im good with the first one? The iuniker one is so much more then it's in the us for some reason. Also should I get better thermal tape for the heatsinks. Which one's.
                                • RiverstormR
                                  Riverstorm @Deltax5
                                  The first one looks fine. I can't say I have a lot of experience on thermal tape. I did some searching on Amazon and found what I though was a decent 3M brand. I didn't see a huge difference between the stock and purchased. It came in a sheet that fits in an envelope and I cut out pieces as needed.
                                  The other thing I noticed about the thermal tape that came stock was it was applied incredibly sloppy and offset on some of the heatsinks missing a 3rd of the surface. I bought what I thought was 6 pieces of aluminum pretty dirt cheap but it actually ended up being 6 sets of 3 so I have them in surplus currently.
                                  I used to cut out squares that took to long and was cumbersome. What I started doing was cut a sqare a little larger than the heatsink. Then I would peel one side off the tape, square up the heatsink and apply the tape. Then I would take a clean razor and cut around the heatsink. It does waste a bit more than trying to cut perfect squares but it's fast and fits like a glove. Then when you're ready peel the backside off and apply. I hope that makes sense.
                                  • caver01C
                                    caver01 @Riverstorm
                                    We have seen a lot of bad accounts of self-adhesive tape for heat sinks. Some cases, it does not conduct heat at all--it insulates, rendering the heat sink useless and making your Pi overheat even more. There are good thermal conducting tapes out there, but you never know what you are getting in a kit, so I always recommend using a good thermal transfer paste like arctic silver, or a two-part CPU compound that will harden as it dries. It's buyer beware, and I find it sad that some folks claim heatsinks are ineffective when the truth may be that they have questionable self-adhesive tape.
                                    RiverstormR D 2 Replies Last reply Reply Quote 0
                                    • RiverstormR
                                      Riverstorm @caver01
                                      I usually keep some AS5 and Shin-Etsu handy (I think it had decent reviews at some point but haven't seen mention of it much lately). Does the heat and grease alone create enough suction/vacuum. How about when it's cool? Have you tried giving a jolt to see how solid it is connected? I might have to try it and do some testing on temp differences.
                                      I've had good success with the tape I've been using. It does peel from the die well but not from the heatsink so readily. I do have plenty of aluminum heatsinks but try and stick to the copper when possible. All probably negligible but still interesting to fiddle with.
                                      • caver01C
                                        caver01 @Riverstorm
                                        @riverstorm I have been using AS5 with a small aluminum sink on my Pi3 CPU for over a year without it moving at all, and my cabinet is a "semi" portable roadcase that have been moved around fair amount. Also, my Pi is mounted upside-down behind the LCD and the sink shows no sign of wiggling loose.
                                        I read somewhere that Arctic Silver will thicken a bit as it goes through hot and cool cycles (power, no power). I expect the moisture starts to break down a bit and it dries out somewhat, though nothing permanent like a 2-part thermal epoxy.
                                        I can see that if I added too much it would really slide around, but with just the right amount you get a good vacuum and the stuff is pretty sticky. Because my sink is cut perfectly to size, there is really nowhere for it to slide, as doing so would slide it off the CPU and that would expose the thermal paste which tends to want to stick to the sink, not release from it.
                                        I just shudder every time I hear someone talk about tape, especially when the instructions for thermal paste have you avoiding even a single air bubble if possible.
                                        • RiverstormR
                                          Riverstorm @caver01
                                          That sounds pretty solid to me. Next time I have the heatsink off I am going try it that way. As you "power cycle" it supposedly cures and improves over time. Maybe a few degrees Celcius.
                                          I think the biggest mistake is using to much thermal grease. To much grease is like driving around city streets in a bumper car. It works and protects you well but it's not optimal for the CPU or temps. I usually just shoot for at least covering the portion of the CPU cover plate that in turn comes in direct contact with the CPU die. I heard of people that de-lid the cover plate to get direct contact with the CPU.
                                          Comparing the Pi to a CPU is like apples to oranges for me a bit. You can run fine most of the time without a heatsink/fan on a Pi. In contrast a modern PC will get you about 8 seconds (bull ride) and a shutdown. Hopefully the mobo did it quickly enough to save the CPU.
                                          Also the Broadcom chip on the Pi (is acrylic?) I would assume whatever the material composition it has a much higher thermal resistance vs. any type of metal. Hopefully any tape between the chip and heatsink has some thermal conductive properties as to not be a complete insulator.
                                          I agree just grease between heatsink and die is definitely better but if all you have handy is tape or it comes as a package deal I don't know if I would drop the extra money for grease. I usually have several syringes of it laying around. The Shin-Etsu has a nasty viscosity that require a little heating to make it workable. AS5 on the other hand is very forgiving and easy to apply.
                                          Yeah air bubbles, fingerprint oil, hair, dust pretty much anything creates an issue. You figure the main purpose of the thermal grease is to fill fill in micro pits, etc. that are probably not visible to the naked eye but people like to goop that stuff on. I think the Pi was designed to run without anything but I know for sure it does run cooler with a heatsink or heatsink/fan combo if your going to push it a little.
                                          • sirhenrythe5thS
                                            sirhenrythe5th @Riverstorm
                                            How about watercooling a Raspberry? Anyone did this yet? 😊
                                            Ok, it sounds like a calculator with a SSD Harddisk - but wouldnt that be "cool"? ☺
                                            RetroRatio: 1.91
                                            Started Games beaten: 2,40%
