    Scummvm controller help
    scummvmcontroller help
    76 Posts 8 Posters 13.4k Views
      bassman6805
      I have a custom built handheld game system similar to the pigrrl but with an analog joystick. I can't seem to get any response from the controller when I open scummvm. I know it's possible to do because I have used an xbox controller on my other pi and didn't have to do anything to get it to work. Here is a link to my config if someone might be able to tell me what to change. Thanks for any help you can give.
      http://pastebin.com/meV1Z70Q
        bassman6805
        Anyone?
        • HurricaneFanH
          HurricaneFan
          Don't most scummvm games need a keyboard?
            bassman6805
            No, I have played some with my xbox 360 controller.
              bassman6805
              I'm willing to try anything if someone has a suggestion.
                bassman6805
                Bumping to see if anyone might have some ideas.
                • E
                  EctoOne
                  Is that a retroarch config that you linked? Because scummvm isn't part of that (as far as I know). I had to set up xboxdrv and mapped some keys to buttons on my pad, including using the analog stick as mouse.
                    bassman6805
                    Yes, that's the retroarch config file. Would you care to tell me how to set up the xbox thing for scummvm? If I set that up will it effect my other systems?
                    • E
                      EctoOne @bassman6805
                      @bassman6805 It won't affect the other systems if you configure it correctly. Luckily the guide in the docs uses scummvm as example.
                        dudleydes @bassman6805
                        @bassman6805 said in Scummvm controller help:
                        When was this? A year ago, ScummVM moved to version 1.9 which uses SDL2 as its backend. Users reported issues when using a joystick so the devs added the SDL1 version to RetroPie.
                        Before you take the xboxdrv route, you may want to try installing scummvm-sdl1 from the RetroPie setup script and testing that.
                        BillyHB 1 Reply Last reply Reply Quote 0
                          bassman6805
                          Thanks. I do have the Scummvm sdl1 installed and still have the same problem. I am going to try the xboxdrv route and see if that works. I decided to backup my sd card before I changed anything and when I put it back in the pi it wouldn't boot. I'll have to figure out what's up with that first. Always something!
                          • ExarKunIvE
                            ExarKunIv @bassman6805
                            @bassman6805
                            i got my mapped with xboxdrv and it works fine for me. so it can be done
                              bassman6805
                              I'm hoping someone can maybe give some more detail on how to fix this. I read through the xboxdrv instructions and it seems way over my head. I don't even see the option to install the xboxdrv in the new version of retropie. Could someone look at my config file I posted and maybe tell me what to change or add?
                              • ExarKunIvE
                                @bassman6805
                                if someone can help you get it installed. ( i cant im running a older version of Pie so for me it was in the driver option in the RetoPie setup).
                                i can help you with getting it mapped
                                  bassman6805
                                  It's my understanding that the xboxdrv installed automatically now in some of the newer versions but I could be mistaken.
                                  • ExarKunIvE
                                    @bassman6805
                                    oh, well that's cool.
                                    let me know what you need help with when you try messing with mapping.
                                    unless someone else has a better idea
                                      bassman6805
                                      Ok. Should I jump to section 3a of the guide you posted or do I need to do something else?
                                      • ExarKunIvE
                                        @bassman6805
                                        if you have what your controller is called and what the buttons pin outs read then yes.
                                        if you dont then you want to start from the beginning.
                                          bassman6805
                                          I don't know if it has a name. Here is what is in the config file.
                                          Keyboard input, Joypad and Joyaxis will all obey the "nul" bind, which disables the bind completely,
                                          rather than relying on a default.
                                          input_player1_a = "z"
                                          input_player1_b = "x"
                                          input_player1_y = "a"
                                          input_player1_x = "s"
                                          input_player1_start = "enter"
                                          input_player1_select = "escape"
                                          input_player1_l = "q"
                                          input_player1_r = "w"
                                          input_player1_left = "left"
                                          input_player1_right = "right"
                                          input_player1_up = "down"
                                          input_player1_down = "up"
                                          input_player1_l2 =
                                          input_player1_r2 =
                                          input_player1_l3 =
                                          input_player1_r3 =
                                          This is also the controller I am using. It works fine for everything else.
                                          • ExarKunIvE
                                            @bassman6805
                                            hmmm
                                            well for mapping you need a bit more.
                                            you need to run this first so you can get the info that is needed
                                            cat /proc/bus/input/devices will pull up something like this.
                                            I: Bus=0005 Vendor=2dc8 Product=3810 Version=0100
                                            N: Name="8Bitdo FC30 Pro"
                                            P: Phys=b8:27:eb:47:c7:78
                                            S: Sysfs=/devices/platform/soc/3f201000.uart/tty/ttyAMA0/hci0/hci0:11/0005:2DC8:3810.0005/input/input6
                                            U: Uniq=e4:17:d8:7a:6a:7d
                                            H: Handlers=js2 event6
                                            B: PROP=0
                                            B: EV=1b
                                            B: KEY=ffff0000 0 0 0 0 0 0 0 0 0
                                            B: ABS=30627
                                            B: MSC=10
                                            ls /dev/input/by-id/ will look like this
                                            pi@retropie:~ $ ls /dev/input/by-id/
                                            usb-1d57_ad02-event-kbd         usb-_Mini_Keyboard-event-kbd
                                            usb-1d57_ad02-if01-event-mouse  usb-_Mini_Keyboard-if01-event-mouse
                                            usb-1d57_ad02-if01-mouse        usb-_Mini_Keyboard-if01-mouse
                                            evtest /dev/input/event[•] will pull this
                                            Input driver version is 1.0.1
                                            Input device ID: bus 0x5 vendor 0x2dc8 product 0x3810 version 0x100
                                            Input device name: "8Bitdo FC30 Pro"
                                            Supported events:
                                              Event type 0 (EV_SYN)
                                              Event type 1 (EV_KEY)
                                                Event code 304 (BTN_SOUTH)
                                                Event code 305 (BTN_EAST)
                                                Event code 306 (BTN_C)
                                                Event code 307 (BTN_NORTH)
                                                Event code 308 (BTN_WEST)
                                                Event code 309 (BTN_Z)
                                                Event code 310 (BTN_TL)
                                                Event code 311 (BTN_TR)
                                                Event code 312 (BTN_TL2)
                                                Event code 313 (BTN_TR2)
                                                Event code 314 (BTN_SELECT)
                                                Event code 315 (BTN_START)
                                                Event code 316 (BTN_MODE)
                                                Event code 317 (BTN_THUMBL)
                                                Event code 318 (BTN_THUMBR)
                                                Event code 319 (?)
                                              Event type 3 (EV_ABS)
                                                Event code 0 (ABS_X)
                                                  Value    128
                                                  Min        0
                                                  Max      255
                                                  Flat      15
                                                Event code 1 (ABS_Y)
                                                  Value    127
                                                  Min        0
                                                  Max      255
                                                  Flat      15
                                                Event code 2 (ABS_Z)
                                                  Value    128
                                                  Min        0
                                                  Max      255
                                                  Flat      15
                                                Event code 5 (ABS_RZ)
                                                  Value    127
                                                  Min        0
                                                  Max      255
                                                  Flat      15
                                                  Resolution      46
                                                Event code 9 (ABS_GAS)
                                                  Value      0
                                                  Min        0
                                                  Max      255
                                                  Flat      15
                                                Event code 10 (ABS_BRAKE)
                                                  Value      0
                                                  Min        0
                                                  Max      255
                                                  Flat      15
                                                Event code 16 (ABS_HAT0X)
                                                  Value      0
                                                  Min       -1
                                                  Max        1
                                                Event code 17 (ABS_HAT0Y)
                                                  Value      0
                                                  Min       -1
                                                  Max        1
                                              Event type 4 (EV_MSC)
                                                Event code 4 (MSC_SCAN)
                                            Properties:
                                            Testing ... (interrupt to exit)
