    My first 'Pi' Project, Advice and help.
    helphow toretropie
    1 Posts 1 Posters 596 Views
      gallagj8
      Hi,
      Let me start by outlining but skillset, my IT skills are above average but my programming skills are next to nothing.
      What I have is a product I backed on Kickstarter a few years ago, which no longer is support (I don't mind so much, as it has just been collecting dust for a while now, as I no longer use it as a media player). The product is call Slice, created by FiveNinjas. (See It HERE)
      It came with Compute Module 1 although I am going to upgrade it to Compute Module 3.
      What I would like to know is once I put CM3 in it, would it be possible to complete wipe and then install RetroPie onto it (maybe with a duel boot to Kodi, or can Kodi be accessed in RetroPie OS (either way Kodi isn't too important))
      Would CM3 be powerful enough to handle most Emulators?
      I think the Slice would be an ideal console as I has the ports required (WiFi, Built in Bluetooth, USB, Ethernet) and has a built in 1TB harddrive which would be more than enough for storing a good catalogue of games on. Also, it already looks the part in its nice wee case.
      Any help or advice whatsoever would be appricated.
