    I ruined genesis.....help
    dispmanx
    6 Posts 2 Posters 1.5k Views
      dogeymon
      I watched a video online that told me to go to retropie settings and configure emulators to use dispmanx SDL......well since I selected that, genesis games don’t run quite as well. They stutter a bunch now and the sound screws up
      I wish I had never selected that. I can’t seem to figure how to put it back how it was. Anyone know?
      HyruleslinkH 1 Reply Last reply Reply Quote 0
      • HyruleslinkH
        Hyruleslink @dogeymon
        @dogeymon You should be able to disable dispmanx by going back to where you enabled it in RetroPie setup. Just select it and press enter.
          dogeymon @Hyruleslink
          @hyruleslink
          Really? Ok it just doesn’t act like anything is different. The selection says the same thing every time I go to the menu. No message anywhere is saying if I turned it off or on.
          But if you’re sure well then I did.
          • HyruleslinkH
            @dogeymon Did that do the trick? Is everything good with your Genesis gameplay now?
              @hyruleslink
              I think so thanks
              HyruleslinkH 1 Reply Last reply Reply Quote 1
              • HyruleslinkH
                @dogeymon Good to hear! Also try switching up your emulators if some games aren't working great. If I remember correctly, Pier Solar didn't work well with the default Genesis emulator but when I used a different one, it ran much better. Glad your Genesis isn't ruined :)
