    Sound barely works
    soundsound problemsound problems
    16 Posts 5 Posters 4.1k Views
    • E
      EP
      So I've been using RetroPie for a while, and this only happened recently. In every NES emulator, every Atari 2600 emulator and every MAME emulator I have been getting some sound and it only appears for split seconds at a time and mute. I've tried using hdmi_drive=2 but still no luck. I am using an HDMI cable by the way, which hooks up to an HDMI port on a Roku TV.
        edmaul69 @EP
        @ep in emulationstation in the main menu there is a volume control. Make sure it is at 100%
        • E
          EP @edmaul69
          @edmaul69 said in Sound barely works:
          That's not the problem, tried it as well. I'm going to do a sound sample on video so there is more clarification.
          edmaul69E E 2 Replies Last reply Reply Quote 0
            edmaul69 @EP
            @ep ok. Just wanted to make sure.
            • E
              EP @EP
              @ep said in Sound barely works:
              glennlakeG ruckageR 2 Replies Last reply Reply Quote 0
              • glennlakeG
                glennlake @EP
                @ep Can you give us a little more info? Please follow the advice at the top of each page. https://retropie.org.uk/forum/topic/3/read-this-first
                • ruckageR
                  ruckage @EP
                  @ep
                  It sounds like the sound is cutting out completely, it's possible it could be hardware related.
                  You say you have it hooked up through a roku TV, have you tried connecting directly to the TV to rule out the Roku being the problem? It may also be worth trying a different HDMI cable to rule that out as a cause.
                  E 1 Reply Last reply Reply Quote 1
                  • E
                    EP @glennlake
                    @glennlake said in Sound barely works:
                    It is a Roku TV using HDMI and the sound barely works on RetroPie. You can watch the video and it will have audio samples.
                    • E
                      EP @ruckage
                      @ruckage The entire TV is a Roku on itself. It's made by Insignia.
                      • ruckageR
                        ruckage @EP
                        In that case first try a different HDMI cable. If it still doesn't work try it on a different TV, that way we can narrow down where the problem lies.
                        • simonsterS
                          simonster
                          Can you fill in the details requested from the https://retropie.org.uk/forum/topic/3/read-this-first as @glennlake has already requested. By failing to do this, it is making it very difficult to diagnose.
                          These are the details required:
                          Pi Model or other hardware: (B, B+, 2 B, 3, X86 PC etc..)
                          Power Supply used: (If using a Pi)
                          RetroPie Version Used (eg 3.6, 3.8.1, 4.1 - do not write latest):
                          Built From: (Pre made SD Image on RetroPie website, Berryboot, or on top of existing OS etc.. - please provide the filename of any image used)
                          USB Devices connected:
                          Controller used:
                          Error messages received:
                          How to replicate the problem:
                          • E
                            EP
                            RPi3 Model B
                            Default power supply that comes with Vilros Raspberry Pi 3 Model B Pack|
                            RetroPie 4.3|
                            Self install 16 GB MicroSDHC with RetroPie OS (retropie-4.3-rpi2_rpi3.img)|
                            PLAY Xbox One Controller and PowerA Xbox 360 Controller|
                            http://ibb.co/df9hrG http://ibb.co/epjRJw|
                            None|
                            All|
                            Ok I really can't because it would take too long to copy and paste the whole thing through SSH|
                            IDK
                            • E
                              EP @ruckage
                              @ruckage That appeared to fix the problem, I'll come back to the forum if there is another problem. Thanks!
                              • E
                                EP @EP
                                It is back to itself again. :(
                                • ruckageR
                                  ruckage @EP
                                  @ep
                                  If changing the HDMI cable worked at first then that suggests it could be a problem with the hdmi socket either on the PI or the TV. Do you have another hdmi port on the TV that you can try?
                                  • E
                                    EP
                                    I think it would be useful to note that the menu plays noises perfectly and the video goes extremely smooth.
