Navigation
    • Search
    SD Card Corruption
    Help and Support
    corrupt corrupt sd sd card sd card failure sony
    7
    16
    3891
    • demesauce
      demesauce Banned last edited by demesauce
      Pi Model or other hardware: Rpi 3B
      Power Supply used: 3a power brick
      RetroPie Version 4.3
      Built From RetroPie website
      USB Devices connected: Tronsmart wireless adapter
      Controller used: Tronsmart G01
      Error messages received: EXT4-fs error (device mmcblk0p2): ext4_mb_generate_buddy:758: group 33, block bitmap and bg descriptor insonsistent 0 vs 32768 free clusters
      How to replicate the problem: Seems to occur when adding large roms (Sega CD and PSX). After I have the system up (after the initial configuration), it'll be sitting idle, then this starts to pop up 2_1506976003231_IMG_0652.JPG 1_1506976003231_IMG_0651.JPG 0_1506976003230_IMG_0650.JPG
      demesauce 1 Reply Last reply Reply Quote 0
      • demesauce
        demesauce Banned @demesauce last edited by demesauce
        Also, I am using a New Sony 64GB microSDXC micro SD SDXC Class 10 card. After this message the Pi restarts and a recovery tool begins to try to "fix the drive" after a while the pi reboots. Everything seems ok for a bit, but the same problem continues.
        But I have gotten the same error with serveal new 32gb Sandisk micro SD SDXC Class 10 cards. Normally I take the sd cad out format it and start from scratch. Usually with the same results.
        jonnykesh ortsac 2 Replies Last reply Reply Quote -1
        • jonnykesh
          jonnykesh @demesauce last edited by
          @demesauce Since you have tried a few other cards I would suggest that the image you have is somehow corrupted. Download it again and verify the checksum before you write the image. Try etcher.io to write the image this time, that seems to work 99.+% of the time. Win32DiskImager can be a bit hit and miss sometimes.
          • demesauce
            demesauce Banned @jonnykesh last edited by
            @jonnykesh So that's just it. When I was having the problem with the 32gb SanDisk cards, I tried to download the image again, same problem I even grabbed an older version, same thing. Tried a different card reader, same again. And SanDisk cards are known for being robust and not as prone to corruption.
            But I'll give etcher.io a shot, thanks
            jonnykesh 1 Reply Last reply Reply Quote 0
            • jonnykesh
              @demesauce did you verify the checksum?
              • demesauce
                @jonnykesh No, is there a linux command to verify?
                jonnykesh 1 Reply Last reply Reply Quote -1
                • jonnykesh
                  @demesauce md5sum /path/to/file
                  • demesauce
                    @jonnykesh Thanks, I'll give it a shot.
                    • demesauce
                      Still no luck. Used Etcher, it copied and verified. But while coping ROMS, same errors
                      edmaul69 1 Reply Last reply Reply Quote -1
                      • edmaul69
                        edmaul69 @demesauce last edited by
                        @demesauce you probably should use something like winscp on your computer to transfer large roms.
                        • Deltax5
                          Deltax5 last edited by
                          If you can't reformat it and if it does boot up. easy way to check if the card is bad is loading up a game and save then reboot if it doesn't keep your save your card is bad.
                          If it's actually a bad card contact the manufacture first maybe they can send you another card if you have proof of perches.
                          • demesauce
                            demesauce Banned @edmaul69 last edited by
                            @edmaul69 I have a Mac and use Transmit. Seems to be a pretty popular option on Macs
                            • edale
                              edale last edited by
                              You might consider running a program like H2testw (Windows only IIRC, not sure what similar Linux program would be) to verify you have good SD cards.
                              That sounds like the type of error you might get from a fake one (2/4GB SD card formatted to look like a 32 GB card and such).
                              • ortsac
                                ortsac @demesauce last edited by
                                @demesauce It could be that the SD cards you're using are not compatible for RPi or Retropie. Checck yours here: https://elinux.org/RPi_SD_cards
                                The list may not have been updated recently but you get a general idea that not all SD cards will play well.
                                • BuZz
                                  BuZz administrators last edited by BuZz
                                  It's unlikely a compatibility issue - It's far more likely they have bought cheap fake cards, or they are possibly faulty. There are a lot of fake cards out there - make sure you buy from reputable companies.
                                  • demesauce
                                    If it was in fact a Sony card, it should be compatible. I have to admit, bought it off eBay, probably fake, like BuZz suggested.
