    Disabling over-scan ruining resolution issue
    resolutionoverscansplash-videosplash screen
    4 Posts 3 Posters 1.4k Views
      Blasterbrew
      Hi everyone, I am attempting to add a video as a splash-screen for when the retropie starts up. I have been following the tutorial on this YouTube video:
      I am able to add it just fine, but it was mentioned in the comments to disable Over-scan since the splash screen kept on flickering and such. It worked, but now the resolution is way off on my retropie. I tried changing the resolution settings, but it doesn't fix the problem. I can only fix it by re-enabling Over-scan and removing the splash screen. Can anyone help me on this? Thanks in advance!
        dankcushions Global Moderator @Blasterbrew
        @blasterbrew i would follow the guides in the docs: https://github.com/RetroPie/RetroPie-Setup/wiki/splashscreen - they don't mention overscan.
          Blasterbrew
          Thanks for the response but I did what the link you sent states and I still get the issue :(
          • chipsnblipC
            chipsnblip
            need more info about your setup
