    Emulator help
    gamecube
    4 Posts 3 Posters 903 Views
      ScienceGamer004
      Are you able to add emulators like GameCube to the pi 3
      • jonnykeshJ
        jonnykesh @ScienceGamer004
        @sciencegamer004 No. The Pi will never run a GC emulator. Well maybe at a single frame per second.
        S caver01C 2 Replies Last reply Reply Quote 0
          ScienceGamer004 @jonnykesh
          @jonnykesh ok thanks I just needed confirmation
          • caver01C
            caver01 @jonnykesh
            @ScienceGamer004 But, in all fairness to emulators "like GameCube", another answer could be YES, the Pi3 running RetroPie DOES let you add many MANY emulators "like GameCube", but simply not GameCube, as it would be too slow for that. Insomuch as the GameCube is "like" the NES (both are home consoles, albeit vastly different generations), depending on your needs, the Pi3 is a great option.
