    help a noob
    bios psx
    9 Posts 5 Posters 1.6k Views
      koooowweeee
      hi
      just got my r pi3
      ive flashed retropi and it boots up ok. ive got myself a few roms on a dongle and they detect in retropi
      when i try to play a game it says error logged to dev/shm/rumcommand.log so i do a quick google which tells me i need a bios.
      so... ive come here to find one or a tutorial but i cant seem to find one.
      i want to play ps1, snes, mega drive etc.
      any help is more than grateful, cheers
      BuZzB 1 Reply Last reply Reply Quote -1
      • space cadetS
        space cadet
        For ps1 you do need a bios file. Google will find them.
          koooowweeee
          it does say in my post ive tried that.
          i dont know what do do, thats why i made the tread
          • jonnykeshJ
            jonnykesh @koooowweeee
            @koooowweeee tried what?
              koooowweeee
              @jonnykesh googleing
              • jonnykeshJ
                @koooowweeee did you look for the file name or just try "playstation bios"?
                  koooowweeee
                  I don't know the name of the file. I've just looked in the sub sections for info on it.
                  I'm a total noon I've had the pi a few days. I've got the mega drive games to work and a N64 game. Although it didn't run well at all. Seemed to run at 17fps
                    mitu Global Moderator @koooowweeee
                    @koooowweeee Start with https://retropie.org.uk/docs/, each emulator has it's own detailed description, including whether it needs a bios file, what's the bios name and checksum.
                    Just like the RetroPie doesn't distribute ROMs, the forums are not a place to ask for or point to ROMs or other copyrighted material, so you'll not find a link to the BIOS files here.
                    Start with the docs and if you still have problems - ask away.
                      BuZz administrators @koooowweeee
                      @koooowweeee Please do not post a support request without first reading and following the advice in https://retropie.org.uk/forum/topic/3/read-this-first
                      (Which you are asked to read and agree to on registration. You provided none of the information requested. You should use a topic title that summarises your problem - not "help a noob").
                      Please edit your post and use a sensible topic.
