    Extras for RetroPie themes (icons, splashscreens and launching images) | es_theme_extras shell script
    themesshell scriptsplashscreensiconslaunching image
    5 Posts 2 Posters 2.3k Views
    • hiulitH
      hiulit
      This is my first shell script ever, so there are surely code errors. Contributing is most welcomed.
      This script let's you install some extras for RetroPie themes. These extras are:
      • Icons
      • Splashscreens
      • Launching images
      Install Pixel
      Update or Uninstall Pixel
      Extras
      Install Pixel icons
      Install Pixel splashscreen
      Choose splashscreen
      Install Pixel launching images
      Installation
      cd /home/pi/
      git clone https://github.com/hiulit/es-theme-extras.git
      cd es-theme-extras/
      sudo chmod +x es-theme-extras.sh
      sudo ./es-theme-extras.sh
      The big issue
      At this moment, Pixel by @Rookervik is the only theme that works with this script because it's the only one (that I know of) that has icons, splashscreens (16:9 and 4:3) and launching images.
      Pixel theme has both icons and splashscreens in the same repository and launching images has its own repository.
      This script is created under these premises:
      • Icons and splashscreens must be in the same repository https://github.com/USERNAME/es-theme-THEME.
      • Icons must be in path /retropie/icons.
      • Splashscreens must be in the root path and named splash16-9.png and/or splash4-3.png.
      • Launching images must be in another repository https://github.com/USERNAME/es-runcommand-splash.
      I think that could be standarized so that every theme could take advantage of this script.
      Proposal for standarization
      I propose two versions:
      • Self-contained (all extras in the same repository).
      • Diferent repositories for each extra (icons, splashscreens and launching images).
      When the decision is made, I'll make the necessary changes according to the version agreed upon.
      Self-contained (same repository) version
      • Theme URL: https://github.com/USERNAME/es-theme-THEME
      • Icons URL: https://github.com/USERNAME/es-theme-THEME/retropie/icons
      • Splashscreens URL: https://github.com/USERNAME/es-theme-THEME/retropie/splashscreens
      • Launching images URL: https://github.com/USERNAME/es-theme-THEME/retropie/launching-images
      Diferent repositories version
      • Icons URL: https://github.com/USERNAME/es-theme-THEME-icons
      • Splashscreens URL: https://github.com/USERNAME/es-theme-THEME-splashscreens
      • Launching images URL: https://github.com/USERNAME/es-theme-THEME-launching-images
      Where USERNAME is GitHub's username and THEME is the theme's name.
      Filetype, naming convention and formatting
      In both cases the filetype, naming convention and formatting must be the same, as follows:
      Icons
      Filetype
      • Icons must be .png filetype
      Naming conventions
      Names must be the same as RetroPie's default icons:
      See https://github.com/RetroPie/RetroPie-Setup/tree/master/scriptmodules/supplementary/retropiemenu/icons
      Formatting
      Same as RetroPie's default icons:
      • Names must be all lowercase
      • No spaces
      Splashscreens
      Filetype
      • Image splashscreens must be .png filetype
      • Video splashscreens must be .mp4 filetype
      Naming conventions
      Images
      Videos
      • THEME-splashscreen-video.mp4
      e.g pixel-splashscreen-video.mp4
      Formatting
      • Spaces must be hyphens
      Launching images
      Filetype
      Launching images must be .png or .jpg filetype
      Naming conventions
      • SYSTEM_NAME/launching.png
      e.g. nes/launching.png
      See https://github.com/ehettervik/es-runcommand-splash
      Formatting
      • No spaces
      What are your thoughts?
      Do you find it useful? Do you think it could be integrated in RetroPie officially?
      Maybe @meleu has some insights, code related?
      Also, it would need every theme creator to get involved for this script to be useful.
      @Rookervik @ruckage @Omnija @lilbud to name a few.
      Thank you!
      P.S. Filetype, naming conventions and formatting taken (partially and revisited) from retropie-splashscreens-extra repository by @herb_fargus
      My little contributions to the RetroPie project:
      • Shell-Script-Boilerplate
      • Fun-Facts-Splashscreens
      • Limit-Last-Played-Games
      meleuM 1 Reply Last reply Reply Quote 3
        meleu @hiulit
        @hiulit I'm not a theme developer, but I suggest using a different repo for launching images. Because an ES theme, is an EmulationStation stuff, and launching images are runcommand stuff.
        By the way, the most critical part I'm seeing is standardizing the names/paths in launching-images repositories.
        Look how many of them we have so far (how different they are):
        • @Rookervik 's pixel: https://github.com/ehettervik/es-runcommand-splash
        • @lipebello 's Retrorama: https://github.com/lipebello/retrorama-launching-images/
        • @ruckage 's nes-mini: https://github.com/ruckage/nes-mini-theme-launch-images-for-retropie
        • @TMNTturtlguy 's ComicBook: https://github.com/TMNTturtleguy/ComicBook-Theme-Launch-Images-for-Retropie/
        hiulitH 1 Reply Last reply Reply Quote 1
        • hiulitH
          hiulit @meleu
          @meleu Yes, I also think a different repo for launching images would be the best solution. And now that you mentioned why it would be best to separate ES themes and launching images, do you think that the icons should be in the Es theme repo? Like Pixel theme does https://github.com/USERNAME/es-theme-THEME/retropie/icons
          I've also noticed that they have different folders for variations of their launching images, like aspect ratios. I haven't thought of that, and neither my script nor my proposal had that into account when I wrote them.
          I would like to know what @Rookervik , @lipebello , @ruckage , @TMNTturtlguy think about this :)
          Also @meleu , when you have the time, no pressure at all, I would really appreciate if you could take a look at the code and guide me on how to improve it (because I'm sure there are tons of errors, hehe)
            meleu @hiulit
            @hiulit said in Extras for RetroPie themes (icons, splashscreens and launching images) | es_theme_extras shell script:
            Yes. Those icons are ES stuff and aren't big files. That's my reason.
            Also @meleu (...) I would really appreciate if you could take a look at the code and guide me on how to improve it
            Currently I'm kinda immersed in another project (the hascheevos tool). But I'll try to take a look at your script later ;-)
            The first thing I would change is that backtitle saying "Backtitle", lol
            hiulitH 1 Reply Last reply Reply Quote 0
            • hiulitH
              hiulit @meleu
              @meleu said in Extras for RetroPie themes (icons, splashscreens and launching images) | es_theme_extras shell script:
              Hahaha, you're right! xD
              But I was waiting because I wanted to know how can I implement RetroPie's variables, for example: $__backtitle or functions, like gitPullOrClone. Do I need to reference other files?
              See https://github.com/RetroPie/RetroPie-Setup/blob/master/scriptmodules/supplementary/esthemes.sh
