    Cannonball no sound/music with USB sound card
    cannonballaudiousb sound card
    1 Posts 1 Posters 630 Views
      GtBFilms
      Hi,
      I've just set up RetroPie 4.3 on my rpi3 from scratch. Everything is working fine, apart from Cannonball has no sound at all.
      Everything else has sound as expected, I am using a USB sound card rather than the 3.5mm audio jack as the sound quality is a lot better.
      If I plug some speakers into my audio jack and configure RetroPie Audio (in the serttings) to use the headphone jack, then Cannonball has it's sound back! However I don't really want to have to change the way my speakers are connected and change settings just to play one game.
      I couldn't see any obvious way to change the sound device in Cannonball's menus - is there something in the config files which I could change to force it to use the correct audio output device - my usb sound card?
      Thanks!
