    Problems Updating to 4.3
    updatingupdate failed
    2 Posts 1 Posters 683 Views
      Cueball99
      Hi guys,
      Fairly new to Retropie so apologies if this is obvious but I am having some problems updating from 4.2 to 4.3.
      Currently I'm running 4.2 on a Pi3 Model B with a Samsung 32gb Evo+ sd card and the official power supply.
      When trying to update I'm coming across two problems depending on how I try to update. If I try updating all packages I get an error saying "Could not install package(s):vlc". All seems fine after a reboot until I try to access Retropie Config, it just fails to load and sends me back to EmulationStation, tried this three times, same result each time.
      The other problem I have is if I try a basic install instead. All seems OK until I restart, EmulationStation then fails to load at all and I get an error message stating "cannot execute binary file". Again tried updating this way three times and same result each time.
      Having spent a fair bit of time setting everything up I don't really want to do a fresh install but is this my only remaining option?
      I would be grateful for any imput you can give me.
      Cheers
        Cueball99
        Anyone able to help me with this at all?
